Open Excel file from ACAD
wales123456
Message 1 of 11
wales123456
Hi everyone
I am trying to open a drawing register from inside acad and the following is the code I have so far:
(defun c:rg (/ path filename program)
  (setq path (vl-string-right-trim "\\" (getvar 'dwgprefix))
        path (substr path 1 (vl-string-position (ascii "\\") path 0 T))
  (setq filename (strcat path "\"QCL Issue Register.xlsm")
  (setq program "C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\\EXCEL.EXE")
  (startapp program filename))
(princ))
Could someone please advise why it isn't working?
Replies (10)
Message 2 of 11
ВeekeeCZ
@Anonymous wrote:
Hi everyone
  (setq filename (strcat path "\"QCL Issue Register.xlsm"))
  (startapp program filename)😉
(princ))
Try it like this.
Check the path, I have no root in mine.
You have too many or missing parenthesis, \\ wrong.... see the red ones.
  (setq filename (strcat path "\\QCL Issue Register.xlsm"))
  (setq program "C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\EXCEL.EXE")
  (princ))
Message 3 of 11
wales123456
Thanks for your swift response BeekeeCZ
I now have this as the code
(which I think is what you have advised)
(vl-load-com)
(princ))
but acad gives me the following error when I load the lisp in:
too few arguments in SETQ: (SETQ PATH (VL-STRING-RIGHT-TRIM "\\" (GETVAR (QUOTE DWGPREFIX))) Â PATH (SUBSTR PATH 1 (VL-STRING-POSITION (ASCII "\\") PATH 0 T)))
any ideas?
Message 4 of 11
ВeekeeCZ
Please read my previous answer again and fix it.
Little modified version, but never received your error.
(vl-load-com)
(defun c:rg (/ path filename)
  (if (findfile (setq path (vl-string-right-trim "\\" (getvar 'dwgprefix))
                      filename (strcat path "\\QCL Issue Register.xlsm")))
    (startapp "C:\\Program Files (x86)\\Microsoft Office\\root\\Office16\\EXCEL.EXE" filename)
    (princ "\n'QCL Issue Register' File not found."))
(princ))
Message 5 of 11
wales123456
Thanks BeekeeCZ
The LISP works now but when it opens excel, it tries to open K:\Projects\2016.xlsx
, then tries to open Projects\16899.xlsx, then New.xlsx, then Road.xlsx, etc..
The drawing is located here:
K:\Projects\2016 Projects\16899 New Road Residential\Draw\C-121 Location Plan.dwg
Do I need to put double quotation marks in as there are spaces in the folder names? Or is it something to do with the path variable?
Thanks again.
Message 6 of 11
ВeekeeCZ
I need the relation between dwg and xls file.
So you gave me dwg path.
Where is your QCL Issue Register.xlsm located?
Message 7 of 11
wales123456
K:\Projects\2016 Projects\16899 New Road Residential\QCL Issue Register
Message 8 of 11
ВeekeeCZ
Yes, you're right. Needs to be wrapped in quote marks.
(vl-load-com)
                      filename (strcat "\"" path "\\QCL Issue Register.xlsm\"")))
(princ))
Message 9 of 11
wales123456
perfect
thank you very very much. I really appreciate it.
(do I give you Kudos as well as accept as solution?)
Message 10 of 11
ВeekeeCZ
You should definitely mark the final answer as the solution if it solve your problem - it's a technical thing.
Kudos are more about emotions, if you were pleased.... see the VIDEO. Actually I've saw that now for the first time - It was just as a text before...
Message 11 of 11
Ranjit_Singh
Just a suggestion that do not hard code the path of the application. If you went to office 14 or 20 or something else in future; or you got rid of root or something of that sort, it may not work. As @ВeekeeCZ pointed out he did not have root on his computer. I was testing on mine and I still have Office 14.
