Visual LISP, AutoLISP and General Customization
195 Views, 2 Replies
Script
I want an script that when dragged to the acad window will put the location of the script to the search path. Possible???
2 REPLIES 2
ezcad.co.uk
First, save the attached lisp file into a "support" folder then create a script file which contains something like:
(load "path.lsp")(path "C:\\EzCAD")
HTH
Steve
Thank you very much man. Well, it would be better if i don't have to edit the script depending on on its location. Meaning the script or the lsp should locate itself. When we drag the lsp file to autocad there appears something like "(load "c:/bla/bla/bla)". For script: _script <>:c:/bla/bla. How can i get the paths displayed. I used to try (getvar "lastprompt") but I'm having trouble if the path is too long. Thanks any way...
Forma Design Contest
AutoCAD Beta
