Scale in X/Y/BothXY/ Definied Direction
09:07 PM
- Mute
- Permalink
- Report
I wonder if there is possibility to write lisp for "Select Objects to Scale them in X/ Y/ Both X and Y/ Definied Direction" (Direction would be definied by picking two Points)?
This is very necessary option, which is missing in AutoCad... To be able to do so, you have to write a Block, than you can scale in X/Y direction in Properties tool (Ctrl+1), but then you could explode this Block (only if you check "allow exploding" option when you wrote this Block).
But I want to have possibility to scale in X and Y direction without writing a Block.
This problem was touched here:
"Select Rectangles to change their Lenths and Widths at once."
and I would like to get answer which ends my uncertainty.
