Rotate viewpoint of a UCS
1 REPLY 1
dlbsurveysuk
166 Views, 1 Reply
I'm having a bit of a mental blockage...
I'm in a UCS set to UCS>View so the Viewcube shows TOP. I can click the Viewcube and the view will rotate 90 about the x-axis to show FRONT in the same UCS.
My question is - how do I do this from the command line, so I can incorporate it into a Lisp routine?
Thanks.
1 REPLY 1
dlbsurveysuk
in reply to: dlbsurveysuk
Blockage over. This works.
(command "UCS" "X" "90" "")
(command "PLAN" "")
(command "UCS" "X" "-90" "")
Forma Design Contest
AutoCAD Beta
