room names to attribute
Message 1 of 21
I need a lisp routine that will allow me to pick a room name or location and then pick a block and have it fill in the "location attribute". The blocks would be fire alarm and security device placed on a floor plan. I would then use data extraction to pull the attribute info for filling in excel spreadsheet. Ideally it would have a dialog block for putting in a prefix, I could type in something like "1st floor bldg A" If anyone has anything or can get me sent in the right direction I would be very appreciative for the help. I haven't done autolisp code writing for several years.
Thank You
Rick
Replies (20)
Message 2 of 21
Sea-Haven
Post a example dwg with the relevant block.
Message 3 of 21
Here's a sample drawing with a card reader and a camera block which is typical of what we use
Message 4 of 21
Sea-Haven
I can see a lot of possible problems, but it is possible to find all blocks using a text on a layer.
Step 1 is find a text
Step2 is make a bpoly
step 3 is get all text and any blocks
Step 4 is make some form of list as you require
So yes its possible, re card reader it was on outside of building so a problem. Needs a different search method, a touch rather than within.
A better sample would be good with more blocks. To test code. This should exist already some one will have I just have the method somewhere. Need out put sample like
"Level 2" desription1 description2 Block1name atts……..
"Level 2" desription1 description3 Block1name
"Level 2" desription1 description4 Block1name atts...........
Message 5 of 21
pbejse
Not enough information for me to follow,  on your sample dawing file, what is supposed to be the value for LOCATION" on  "CAM-1" block ? is it "LOBBY/AC06"? and a TEXT object at that.
Are you saying "FIXED CAMERA" and "CARD READER" block are already in place?  In your case you have to select the name then the block, there is no easy way.
A lot of times I suggested before to use a "FLOOR" to identify a room on a non-plotable layer.
[ width and color are exagerated for discussion purposes ]
Anyt time a program need to identify what's in a room, it uses the floor as the boundary along with the use of filters.
Just bringing it out there for you.
Message 6 of 21
Sea-Haven
Agree lack of information no probs finding stuff inside rooms but need to know what to look for.
Message 7 of 21
I realize I didn't explain myself very good. what I'm looking for is a routine that allows me to pick the room name text and then select a block that located ether by that room or in it. The selected text would be populate the block in a attribute which when I completed I could use data extraction to fill in a spreadsheet that would have a block address and location which is used for a spreadsheet schedule. I have a lisp routine that addresses the block as a attribute already. I had worked for a company that had such a process and I would like to use it at my new company
Message 8 of 21
pbejse
@Anonymous wrote:
 ...What I'm looking for is a routine that allows me to pick the room name text and then select a block that located ether by that room or in it
Ok then.
(Defun c:labeltoblock (/ blk txt)
  (while
    (and
      (princ "\nRoom label")
      (setq txt (ssget "_+.:S:E:L" '((0 . "TEXT"))))
      (princ "\nSelect CARD READER/FIXED CAMERA")
      (setq blk (ssget "_+.:S:E:L" '((0 . "INSERT") (66 . 1))))
     (setpropertyvalue
       (ssname blk 0)
       "LOCATION"
       (getpropertyvalue (ssname txt 0) "Textstring")
  (princ)
We were aiming to eliminate the tedious task of selecting one label per block, that is what all this queries and sugestions are all about.
Hope that short routine will work for you
Message 9 of 21
pbejse
In case you need to select tow TEXT objects [ to which there are ]
(Defun c:labeltoblock (/ _2Becomes1 blk txt)
(Defun _2Becomes1 (lst)
 (substr (apply 'strcat
	(mapcar '(lambda (S)
		   (Strcat " "
		       (getpropertyvalue s "Textstring"))) lst))
  	 2
  (while
    (and
      (setq txt (ssget "_:L" '((0 . "TEXT"))))
    (setpropertyvalue
       (ssname blk 0)
       "LOCATION"
        (_2Becomes1 (vl-remove-if 'listp
		      (mapcar 'cadr(ssnamex txt))))
  (princ)
HTH
Message 10 of 21
Sea-Haven
You can get all blocks inside the room by just looking for the text room name, that is easy the issue if you want outside also but how do you define the rules for this by distance ?
A room would return stuff like tables, chairs pc and a camera if within.
Or has Pbe given you the answer.
Message 11 of 21
john.uhden
If each room had a closed polyline (invisible or not), then just text on an appropriate layer for each "attribute" would suffice.  I am thinking that with quadrilateral room outlines my original @Anonymous function could handle finding any piece of data about any room.  No need for blocks unless their curvilinear contents are important to the looks of the finished product.
John F. Uhden
Message 12 of 21
I've been using you lisp routine it works wonderfully except it doesn't recognize Mtext I tried to edit it but I keep getting the error message"ADS request error"
Message 13 of 21
Sea-Haven
(getpropertyvalue (car (entsel)) "Textstring") will return an error for Mtext but not Text, you will need to use either a entget or a Vla-get-textstring method, then the ssget can use *text
Pbejse Bricscad does not support the get and put property methods at present.
Message 14 of 21
		   (Strcat " "
  	 2
  (while
    (and
    (setpropertyvalue
       (ssname blk 0)
       "LOCATION"
  (princ)
I'm a bit inexperienced in lisp programming so I'm a bit confused as to your post. I included the code any help would be apricated
Message 15 of 21
Sea-Haven
2 comments
1 getproperty does not appear to work with Mtext so code needs to use a different method. Probably vla-get-textstring As the code was originally supplied by Pbejse thought he would update. He is a good programmer I expect he will update.
2 A lot of code is used in other software like Bricscad, Intellicad, Autocad Mac, Nanocad etc etc some things work other methods dont. Whilst VL code does not work in Autocad Mac getproperty does.
Message 16 of 21
I tried replacing the getproertyvalue text with vla-get-textstring and it gives a error "too few arguments". I completely lost! any help
Message 17 of 21
dlanorh
What CAD package are you using?
getpropertyvalue only works on (type = ENAME) but doesn't work in some (most) other equivalent CAD packages eg BricsCAD; whilst vla-get-textstring only works on (type = VLA-OBJECT), so you cannot just substitute one for the other without converting between entities (ENAME) and Objects (VLA-OBJECT).
I am not one of the robots you're looking for
Message 18 of 21
I'm using autocad 2021
the below program works great on text but not on mtext. Being inexperience I confused as to why
		   (Strcat " "
  	 2
  (while
    (and
    (setpropertyvalue
       (ssname blk 0)
       "LOCATION"
  (princ)
Message 19 of 21
dlanorh
It only allows the selection of text on unlocked layers in the ssget
If you want to play with "MTEXT" and "TEXT" change
'((0 . "TEXT"))
TO
'((0 . "*TEXT"))
OR JUST MTEXT
'((0 . "MTEXT"))
The '((0 . "TEXT")) is a filter where the 0 is an integer dxf code denoting an entity type and the "TEXT" the type of entity, so this filter means only select "TEXT" entities. Be aware that extracting the text string of an MTEXT entity using
will return any MTEXT inline formatting as part of the string
Message 20 of 21
Sea-Haven
Dlanorh (getpropertyvalue (car (entsel)) "Textstring") returns an error if pick mtext. Text is ok.
Select object: ; error: ADS request error
What are you doing different ?
