Offset polylines
Offset polylines
NoelN.
Message 1 of 15
Offset polylines
NoelN.
Hi everyone,
Does anybody know if possible if there is a lisp routine to offset overlapping polylines from a certain distance. basically I deal with shapefiles  and data and I import them into Map 3d but when I import them into autocad map3d the multiple polylines are on top of each other. let say I have polylines from a A to D but from point B to point C there are 3 polylines over lapping. I want the polylines equally spaced out with out lossing the data attached to the polylines. Hopefully I explained my self correctly..
Replies (14)
Message 2 of 15
sby0531
I suggest you upload the dwg file showing the result that you want so that we can understand your issues well.
Message 3 of 15
NoelN.
here it a sample file the top 2 streets where the polyline are seperated is the final and the bottom one is how it comes out when I uploaded the shape files into the CAD Drawing.
Message 4 of 15
Sea-Haven
I have a chx chy which does just that moves multiple objects by pick in a direction may be useful, you almost need to redraw the plines so the line is parallel off but has a short end connection back to the node.
Message 5 of 15
NoelN.
thank you for that suggestion but I need something automated that will do a large community or area really quick. the suggestion that you mention might take a day or so.
Message 6 of 15
Sea-Haven
How many 1000's ? it would look at say 1 layer at a time you enter offset 1st say 3, second -3 so goes other side. When offer suggestions looking at dwg would expect multiple in one go.
Your lines are on different layers so what is the problem ? There are say 21 in one layer in dwg provided, that's instant redraw do all in one go.
The layer "P-Aerial Distribution Cable" is an easy one to offset, as it appears to have only single segments.
Message 7 of 15
Sea-Haven
This is real rough but shows how the while would be removed for multiple selection. Note works on Lines not plines that needs to be added. offset is 8
(defun c:test ( / end start newst newend obj)
(while (setq obj (vlax-ename->vla-object (car (entsel "Pick object "))))
(setq end (vlax-get Obj 'EndPoint))
(setq start (vlax-get Obj 'StartPoint))
(setq ang (angle start end))
(setq newst (polar start ang 22))
(setq newst (polar newst (+ ang (/ pi 2.0)) 22))
(setq newend (polar end (- 0.0 ang) 22))
(setq newend (polar newend (+ ang (/ pi 2.0)) 22))
(vlax-put Obj 'EndPoint newend)
(vlax-put Obj 'StartPoint newst))
(command "line" newst start "")
(command "line" newend end "")
(princ)
Message 8 of 15
NoelN.
oh I get what your saying now. not 1000's but it's up in the 100's. So basically anything that is over lapping each other in the sample I want them space equally with just a couple clicks.
Message 9 of 15
Sea-Haven
I will clean it up a bit and add some auto do's. Only real question would be offset distance.
1 Enter offset 0 to exit
2 pick a line carefully as they overlap
3 do selection up to user 1, 2 window etc
Message 10 of 15
lena.talkhina
Hello @NoelN. !
Great to see you here on LISP forum.
Don't hesitate to accept a solution if you find one.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 11 of 15
NoelN.
the offset would 5 in decimal US survey Feet
Message 12 of 15
NoelN.
Thank you @lena.talkhina. I'm finding great information and people that are happy to help.
Message 13 of 15
Sea-Haven
Try This please note I isolated the green layer and exploded once so it became line segments between the nodes, so enter offset say 20 pick the green line then window all the green lines.
I am not sure what to do with plines with multi segments I don't think its a quick answer or else diagram loses it joints.
Next version would remake pline with the 2 new lines.
; move and draw a chamfer ends to line and pline
; By Alan H info@alanh.com.au  June 2020
; note pline is 2 vertices only
(defun c:test ( / object  ss off tmp)
(defun aH:add-lines (obj offs / end start newst newend ang)
(if (= (vla-get-objectname obj)"AcDbLine")
(progn
(setq newst (polar start (+ ang 0.785398163397448) (* 1.414 offs)))
(setq ang (angle end start))
(setq newend (polar end (- ang 0.785398163397448) (* 1.414 offs)))
(progn
(if (>  (/ (length (vlax-get obj 'Coordinates)) 2) 2)
(alert "Pline has more than 1 segment\n \n Sorry skipped")
(progn
(setq end (vlax-curve-getEndPoint Obj))
(setq start (vlax-curve-getStartPoint Obj))
(setq newst (polar start (+ ang 0.785398163397448) (* 1.4141 offs)))
(setq newend (polar end (- ang 0.785398163397448) (* 1.4141 offs)))
(setq lst (list (car newst)(cadr newst)(car newend)(cadr newend)))
(vlax-put obj 'Coordinates lst)
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(if (= off nil)(setq off 20 tmp 20))
(setq off (Getreal (strcat "\nEnter offset 0 to exit  " (rtos off 2 1))))
(if (= off nil)(setq off tmp))
(setq tmp off)
(while (setq ent (car (entsel "\nSelect object for layer")))
(setq lay (vla-get-layer (vlax-ename->vla-object ent)))
(setvar 'clayer lay)
(setq ss (ssget (list (cons 0 "*LINE")(cons 8 lay))))
(if (/= ss nil)
(progn
(repeat (setq x (sslength ss))
(setq object (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(AH:add-lines object off)
(princ)
Message 14 of 15
NoelN.
okay awesome thank you @Sea-Haven, sorry for the late response just got busy with work. thank you for the autolisp but I was wondering if possible to not explode anything, because I have data in the polylines.
Message 15 of 15
Sea-Haven
The issue is in the attempting to get a pattern for the multi node connection I may be reading the dwg wrong.
Can you provide a before and after that has different plines, single or multiple. Really need how you want it to look.
