Revision Cloud Macro AutoCAD v2018
Hi all,
I want to start by saying I have no knowledge of LISP, and strictly use macros in AutoCAD.
So I have many, many blocks that I use on a regular basis and I have them all set up to scale based on the LTSCALE I'm using. Sample macro:
*^C^C_.-INSERT;XXXXX;\(/ (getvar 'ltscale) 96);;\CHPROP;L;;LA;XXXX;;
What I want to do is create a macro that will set up my revision clouds in a similar manner. Essentially, go through the prompts and set the min/max arc length as LTSCALE/4 inches. Currently, this is what I've come up with:
^C^CREVCLOUD;A;\(/ (getvar 'ltscale) 4);\(/ (getvar 'ltscale) 4);S;C;P;
Obviously, it isn't working. Can anyone one see where I'm going wrong or offer any suggestions?
Thanks a bunch in advance,
-P
Paul_Gander
Try removing the \ characters. They instruct the macro to accept user input but you are supplying the information needed as part of the macro with the lisp expression.
pendean
Community Legend
Community Legend
Slightly off topic question: is there a chance you might consider creating Annotative Blocks then just avoid all of this forced scaling forever?
Paul,
Thank you for your response. I modified the macro, and something odd happened: While it didn't "work" per se, after running the command the first time, if I "rerun" the command (by pressing Enter) it all works aside from, unfortunately, the arc scaling heh.
Paul_Gander
I think the macro is using an older version of the revcloud command. Try adding ^R after the ^C^C to force it to use the current version. The macro should look like this:
^C^C^Rrevcloud;a;(/ (getvar 'ltscale) 4);(/ (getvar 'ltscale) 4);s;c;p;
Beautiful! It works 🙂
Pendean, good question! There would be a chance, but I've sunk a lot of time into Revit, and use it exclusively for 95%+ of my projects. The updates/corrections that I make to my CUI in CAD is typically for others to use.
