Review my lisp
cneelyPABBX
Review my lisp
cneelyPABBX
Below is the first lisp I have written from “scratch”. And by “scratch” I mean I didn’t take an existing lisp and alter/edit it. However, I did do a little copy/paste from other lisps I have laying around.
I’d like some critique and suggestions about making it more elegant and efficient. It just seems clunky.
What it does is isolate the current layer w/o having to manually select an item on that layer first.
(defun c:LayIsoCurrent (/ s)
 (if (setq s (ssget "_X" (list (cons 8 (getvar "CLAYER")))))
   (princ (strcat "\nNumber of Found objects : < " (itoa (sslength s)) " >"))
 (sssetfirst nil s)
 (command "layiso")
 (princ)
Accepted solutions (3)
Replies (7)
ВeekeeCZ
Good one for start... see notes.
    (progn
      (princ (strcat "\n" (itoa (sslength s)) " objects found."))  ; dont use <>, could be confusing since it marks <ENTER> function. Prefer to use common format.
      ;(sssetfirst nil s)   					   ; no need for this
      (command "layiso" (ssname s 0) "") 			  ; this will also fail in no object is on current layer - wrap it into if...  ;; also, is all objects are on same layer, you can supply just one of them, it would be faster...
  (princ)
Kent1Cooper
If you can live without the report on how many objects there are [what is the purpose of that, anyway?}, you can just do this:
(defun c:LayIsoCurrent ()
 (command "_.layer" "_off" "*" "_no" "")
 (princ)
But if you want that report, I would suggest that it and the isolating parts should all be within the 'then' argument of the (if) function:
   (progn ; then
     (sssetfirst nil s)
     (command "layiso")
   ); progn
 ); if
 (princ)
Kent Cooper, AIA
cneelyPABBX
I dont want the report, but I want to use layiso so that I can then use unlayiso to restore things back.
cneelyPABBX
I did find that out after I posted the code so I'll need to edit to isolate even if no objects exist on the current layer.  How would I supply just one?
Kent1Cooper
@cneelyPABBX wrote:
.... to isolate even if no objects exist on the current layer.  ....
Unfortunately, unlike the LAYDEL command, LAYISO doesn't have an option to specify a Layer name rather than select an object.  If it needs to be via LAYISO in order to have LAYUNISO available later, then I suggest this, which does not depend on whether or not anything is drawn on the Layer:
(defun C:LAYISOCURRENT ()
  (command
    "_.point" (getvar 'viewctr); add an object on the current Layer
    "_.layiso" (entlast) "" ; and use it to pick the Layer
    "_.erase" (entlast) "" ; then get rid of it
  ); command
  (prin1)
Kent Cooper, AIA
cneelyPABBX
That's great! Added cmdecho and I think I'm good with it!
ВeekeeCZ
Similar solution as Kent... just different tools used.
(defun c:LayIsoCurrent (/ s e)
    (progn
      (setq e (entmakex (list '(0 . "POINT") '(10 0 0) (cons 8 (getvar "CLAYER")))))
      (command "layiso" e "")
      (entdel e)))
  (princ)
