Run ConvertPStyles Silent
rich.mikulec
Message 1 of 15
rich.mikulec
I have created the below script to automatically convert a drawing from stb to ctb.
However the command CONVERTPSTYLES always pops up a dialog box requiring a stoppage in the code just to press OK.
If there any way to make this command run silent? Not pop up a Dialog box?
Or is there an alternate way to convert a drawing that is using stb to ctb silently"
I have tried:
  cmdeco 0
  cmddia 0
  variations of
     (command "_.ConvertPStyles" _"Yes")
     (command "_.ConvertPStyles" _"OK")
     (command "ConvertPStyles")
defun STBtoCTB ()
(princ "\nSTBTOCTB----CHECKS PLOT SETTING FOR CTB...DONE\n")
;; Initialize a flag to check if any CTB assignment was made
(setq assignment-made nil)
;; Main function body
(if (= (getvar "PSTYLEMODE") 0) ; Check if the drawing is in STB mode
(progn
(setq oldcmdecho (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
;; Run CONVERTPSTYLES to switch to CTB
;; Assign the specified CTB file to Model Space
(command "._-plot" "y" "model" "Plotter" "Tabloid" "inches" "l" "n" "e" "f" "CENTER" "y" "NewCTB.ctb" "y" "a" "n" "y" "n")
;; Set flag to indicate assignment was made
(setq assignment-made t)
;; Assign the specified CTB file to each Layout in Paper Space
(foreach layout (layoutlist)
(if (/= layout "Model") ; Skip the Model layout if listed
(progn
(command "._-plot" "y" layout "Plotter" "Tabloid" "inches" "l" "n" "e" "f" "CENTER" "y" "NEWctb.ctb" "y" "n" "y" "n" "n" "Y" "n")
(setvar "CMDECHO" oldcmdecho)
;; Only display the message once if any assignment was made
(if assignment-made
(princ "\nThe drawing has been converted from STB to CTB and assigned the specified CTB file to both Model and Paper Space.\n")
;; Message for when no conversion is needed
(princ "The drawing is already using CTB plot styles. No conversion needed.\n")
AutoCAD since Rel 7
AutoCAD 2024 (Mechanical, Electrical, Inventor)
VaultPRO 2024 (Vault Admin)
Inventor 2024 (Design, Factory, Simulate)
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
@rich.mikulec is this what you want
(cond
((= 0 (getvar "PStyleMode")) (command "._ConvertPStyles"))
Message 3 of 15
rich.mikulec
The code works correctly. The issue is with the function of the command:
When this line is run, it posts a msg box that requires an OK response.
I am looking for it to be silent. No intervention.
AutoCAD Mechanical 2024
AutoCAD since Rel 7
Message 4 of 15
Kent1Cooper
Shot in the dark [I haven't looked] -- does the EXPERT System Variable have a value that suppresses that?
Kent Cooper, AIA
Message 5 of 15
rich.mikulec
Yes. I tried 0-5.
AutoCAD since Rel 7
Message 6 of 15
pendean
Community Legend
Community Legend
@rich.mikulec wrote:
...AutoCAD Mechanical 2024
I'm not running MECH, just plain AutoCAD, and the entire code as I wrote exactly converts a named style DWG to a color-dependent with no pop-ups or anything other than a confirmation the DWG got converted.
Tested in plain AutoCAD 2023-24-25, and since you got me intrigued, also in MECH/ARCH/MEP/ELEC/P3D (2023 versions) that just happen to be on my PC, aka still no pop-up and no need to OK out of anything
BUT... MECH2023 above is without add-ons and pretty much an OOTB installation that is fully updated. I don't have any of your STB-centric DWG files to try it on. But you do, or if you can share... ?
Message 7 of 15
rich.mikulec
I just went and copied the code into base vanilla AutoCAD. And it posted the msgbox.
Curious. what happens when you type the command convertpstyles manually? Does it post the msgbox?
File attached
AutoCAD since Rel 7
Message 8 of 15
rich.mikulec
FYI, I added the LSP routine to the CUI Lisp section so that it runs whenever a file is opened.
I did also try with Appload and it acts the same way.
AutoCAD since Rel 7
Message 9 of 15
pendean
Community Legend
Community Legend
@rich.mikulec No pop-ups here, your file is converted silently with a notification at the commandline.
....what happens when you type the command convertpstyles manually? Does it post the msgbox?...
Of course it brings up the dialog box, nothing surprising there.
Message 10 of 15
Rick_Tolleshaug_TSC
If I'm understanding status of this thread, that unlike plain AutoCAD, message still pops-up in AutoCAD Mechanical when called via command function, here is something else to try...
In plain AutoCAD, command ConvertPStyles loads accvps.arx. Assuming AutoCAD Mechanical has its own accvps.arx, wondering if swapping files would do anything? Attached is zipped-up accvps.arx from AutoCAD 2025.1.1, which resides in directory "C:\Program Files\Autodesk\AutoCAD 2025".
Message 11 of 15
rich.mikulec
The issue exists in plain AutoCAD as well for me. I am working in 2024. Did something change in 2024 or any recent updates?
Are there any system variables that could be affecting how convertpstyles operates?
I have tested in 2025 and no popo up. I am investigating if there is a  sysvar difference in 2024.
We are still on Vault 2024, so cannot move yet.
AutoCAD since Rel 7
Message 12 of 15
pendean
Community Legend
Community Legend
...I have tested in 2025 and no popo up. I am investigating if there is a  sysvar difference oin 2024.
Any reason you don't want to adopt and use AutoCAD2025? Just ensure it is at the 2025.1.1 update level.
Message 13 of 15
paullimapa
I'm running 2024.1.6 and I don't get that popup.
Paul Li
IT Specialist
@The Office
Message 14 of 15
Rick_Tolleshaug_TSC
No pop-up for me using (command "convertpstyles") in AutoCAD 2022.1.5, 2024.1.6 or 2025.1.1.
Message 15 of 15
rich.mikulec
I wanted to provide follow-up.
I ended up having to RESET my AutoCAD software. Not sure what got changed, but once that was completed, the commands starting working as expected.
KIM, RESET does just that, brings the software back to its starting point at install. All customizations removed.
Thank you for the help.
AutoCAD since Rel 7
