- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created the below script to automatically convert a drawing from stb to ctb.
However the command CONVERTPSTYLES always pops up a dialog box requiring a stoppage in the code just to press OK.
If there any way to make this command run silent? Not pop up a Dialog box?
Or is there an alternate way to convert a drawing that is using stb to ctb silently"
I have tried:
cmdeco 0
cmddia 0
variations of
(command "_.ConvertPStyles" _"Yes")
(command "_.ConvertPStyles" _"OK")
(command "ConvertPStyles")
defun STBtoCTB ()
(princ "\nSTBTOCTB----CHECKS PLOT SETTING FOR CTB...DONE\n")
;; Initialize a flag to check if any CTB assignment was made
(setq assignment-made nil)
;; Main function body
(if (= (getvar "PSTYLEMODE") 0) ; Check if the drawing is in STB mode
(progn
(setq oldcmdecho (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
;; Run CONVERTPSTYLES to switch to CTB
;; Assign the specified CTB file to Model Space
(command "._-plot" "y" "model" "Plotter" "Tabloid" "inches" "l" "n" "e" "f" "CENTER" "y" "NewCTB.ctb" "y" "a" "n" "y" "n")
;; Set flag to indicate assignment was made
(setq assignment-made t)
;; Assign the specified CTB file to each Layout in Paper Space
(foreach layout (layoutlist)
(if (/= layout "Model") ; Skip the Model layout if listed
(progn
(command "._-plot" "y" layout "Plotter" "Tabloid" "inches" "l" "n" "e" "f" "CENTER" "y" "NEWctb.ctb" "y" "n" "y" "n" "n" "Y" "n")
(setvar "CMDECHO" oldcmdecho)
;; Only display the message once if any assignment was made
(if assignment-made
(princ "\nThe drawing has been converted from STB to CTB and assigned the specified CTB file to both Model and Paper Space.\n")
;; Message for when no conversion is needed
(princ "The drawing is already using CTB plot styles. No conversion needed.\n")
AutoCAD 2024 (Mechanical, Electrical, Inventor)
VaultPRO 2024 (Vault Admin)
Inventor 2024 (Design, Factory, Simulate)
