Hello friends;
To draw a cloud:
1- "Bulutlar" as layer
2- Color color = 30
* Specify approximate length of arc <50>: -- Ask this too. and remember
Thank you so much.
Solved by ВeekeeCZ. Go to Solution.
Try this... BTW These things are really simple, you should try to learn at least the basics. This way you only abuse the generosity of people in this forum.
(defun c:BulutRc ( / l c) (setq l (getvar 'clayer)) (setq c (getvar 'cecolor)) (command "_.-layer" "_t" "Bulut" "_u" "Bulut" "_m" "Bulut" "") (setvar 'cecolor "30") (initcommandversion) (command-s "_.revcloud" "a" 50 "a") (setvar 'clayer l) (setvar 'cecolor c) (princ) )
Then you're thinking of this forum is wrong from the beginning. The purpose of this forum is to help people to learn how to achieve their goals more effectively using customizations. To HELP them LEARN. Not to program anything they may think of.
