I haven't said so but thank you for all your efforts.
Now, here's what's happening. If I start off with no particular drawing open and load the routine, I get a dialog box asking me to select a drawing to export to AutoCAD. Once I pick a drawing, I get an error dialog box, see attachment. When I click OK, I'm back in a Select File dialog box. The file I had previously selected is highlighted, so I click OK, the file opens and the process stops. Nothing else happens.
Starting all over, I open the file I want converted and start the routine. I get a dialog box asking me to select a drawing to export to AutoCAD. The same file I have open is highlighted. I click OK and the routine runs, processes the current open drawing file and then I get the error dialog box in the attachment. When I click OK, I’m back in the Select File dialog box. If I click the Bound- file, the file opens to a command prompt. The Xref’s have been bound in the file, but the blocks are not exploded.
Did I miss a step here somewhere?
Brock
