Message 1 of 15
12:37 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Experts,
I need a small help. The below code can update "all elements inside the blocks to ZERO layer" in entire autocad drawing. But the requirement is code should ask the user for "multiple block selections" instead of applying to entire autocad drawing.
(defun C:nestblockzero (/ BLKDATA NEWCOLOR NEWCOLOR NEWLAYER LAYER XREFFLAG XDEPFLAG BLKENTNAME
COUNT ENTDATA ENTNAME ENTTYPE OLDCOLOR OLDLAYER SSCOUNT SS)
(command ".undo" "group")
(setq BLKDATA (tblnext "BLOCK" t))
(setq NEWCOLOR (cons 62 256)) ;this will set 62 (color) to bylayer
(setq NEWLAYER (cons 8 "0")) ;this will set 8 (layer) to 0
; While there is an entry in the block table to process, continue
(while BLKDATA
(prompt "\nRedefining colors for block: ")
(princ (cdr (assoc 2 BLKDATA)))
; Check to see if block is an XREF or is XREF dependent
(setq XREFFLAG (assoc 1 BLKDATA))
(setq XDEPFLAG (cdr (assoc 70 BLKDATA)))
; If block is not XREF or XREF dependent, i.e., regular block, then proceed.
(if (and (not XREFFLAG) (/= (logand XDEPFLAG 32) 32))
(progn
(setq BLKENTNAME (cdr (assoc -2 BLKDATA)))
(setq COUNT 1)
(terpri)
; As long as we haven't reached the end of the block's defintion, get the data
; for each entity and change its color assignment to BYLAYER.
(while BLKENTNAME
(princ COUNT)
(princ "\r")
(setq ENTDATA (entget BLKENTNAME)); get entities data
(setq OLDCOLOR (assoc 62 ENTDATA)) ;get entities old color value
(setq OLDLAYER (assoc 8 ENTDATA)) ;get entities old layer value
(if OLDCOLOR ; if value exist (null = bylayer)
(entmod (subst NEWCOLOR oldcolor ENTDATA)) ; substitute old color to byblock
(entmod (cons NEWCOLOR ENTDATA)) ; modify ent data w/ byblock values
(if OLDLAYER ; if value exist (null = bylayer)
(entmod (subst newlayer oldlayer ENTDATA)) ; substitute old color to byblock
(entmod (cons newlayer ENTDATA)) ; modify ent data w/ byblock values
(setq BLKENTNAME (entnext BLKENTNAME)) ;if attributes exist, then edit next one
(setq COUNT (+ COUNT 1));
) ;end while for attribute trap
) ;progn
(progn
(princ " XREF...skipping!")
) ;progn
);end if not an Xref
(setq BLKDATA (tblnext "BLOCK")) ;next block please
) ;end while loop of blk data available to edit
(command ".undo" "end")
(command ".regen")
(PROMPT "\nDone... ")
(princ)
Thanks in advance.
