Request to the help: Export LWPolyline Data with crossed (and overlap, inner) text
chauthienqui
Message 1 of 13
chauthienqui
Hello everyone.
Previously, I used lisp EPD (downloaded from another topic), however, there were some obstacles, so I wrote this topic, hoping to receive help from autolisp experts.
Specifically:
I have 2 LWPolyline groups with text overlapping on the contour line, or inside.
After using lisp EPD (attached), the result I received was a csv file as shown below:
I would like to adjust lisp to achieve the following expectations.
1. The single-segment LWpolylines in Group 2: Could export the list of text that crossed (or overlap) with itself.
2. The LWpolylines in Group 1: Dont export the text that isn't crossed the line (i.e: Space 2,space3 with text W02). Keeping export text that cross and be inside the lwpolyline.
3. Text inside polyline (or crossed, or overlap etc..) - Column A: Sort by the Layer name first, then sort by the alphabet of content). with same serepate  by " | "
Other columns: Area, Perimeter, Layer etc,.. please keep it,
There is ACAD file, CSV file, and the lisp file that I used.
I have actually searched the entire forum and really hope someone can help to adjust the lisp code, with at least one issue.
Edit: I post the lisp code EPD that I used
(defun c:EPD (/ all_data area csv_file d data e ent i len openfile pts s ss sstext st)
					; Export Polyline Data
  ;;            pBe Sep 2018            ;;
  (if (and (setq ss (ssget '((0 . "LWPOLYLINE"))))
	   (repeat (setq i (sslength ss))
	     (setq e	(ssname ss (setq i (1- i)))
		   ent	(entget e)
		   area	(vlax-curve-getarea e)
		   ;; RJP » 2019-01-17 added length to results
		   len	(vlax-curve-getdistatparam e (vlax-curve-getendparam e))
		   data	(mapcar '(lambda (d) (cdr (assoc d ent))) '(8 70 5))
		   pts	(mapcar 'cdr (vl-remove-if-not '(lambda (d) (= 10 (car d))) ent))
	     (setq all_data
		    (cons
		      (list
			(cond
			  ((null (setq sstext (ssget "_CP" pts '((0 . "TEXT"))))) "-")
			  ((= (sslength sstext) 1) (cdr (assoc 1 (entget (ssname sstext 0)))))
			  ((substr
			     (apply
			       'strcat
			       (mapcar '(lambda (st) (strcat " | " st))
				       (vl-sort
					 (mapcar '(lambda (s) (cdr (assoc 1 (entget s))))
						 (vl-remove-if 'listp (mapcar 'cadr (ssnamex sstext)))
					 (function (lambda (a b) (< a b)))
			     4
			area
			len
			(car data)
			(if (zerop (logand 1 (cadr data)))
			  "No"
			  "Yes"
			(caddr data)
		      all_data
	     all_data
	   (setq csv_file
		  (getfiled "Save CSV File"
			    (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) ".csv")
			    "csv"
			    45
    (progn (setq openfile (open csv_file "w"))
	   (write-line
	     "Text inside polyline?,Polyline Area (m2),Polyline Length (m),Layer,Closed?,Handle"
	     openfile
	   (foreach itm	(vl-sort all_data '(lambda (a b) (< (cadr a) (cadr b))))
	     (write-line
	       (strcat (car itm)
		       (strcat (rtos (cadr itm) 2 2) )
		       (strcat (rtos (caddr itm) 2 2) )
		       (cadddr itm)
		       (cadddr (cdr itm))
		       (last itm)
	       openfile
	   (close openfile)
	   (startapp "notepad" csv_file)
  (princ)
Replies (12)
Message 2 of 13
pbejse
 Hi @chauthienqui
Can you please post the link of the topic where this was taken so i can understand the original intent of EPD?
Message 3 of 13
chauthienqui
@pbejse Thank for answering
This is the topic that I got the lisp code: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/export-polyline-data-area-layer-and-...
You could see the comment Message #80
Message 4 of 13
pbejse
The quickest fix for this is
						 (if (zerop (Cdr (assoc 70 ent)))  "_F" "_CP" )
But this will not produced the desired result.
For example
Row #7 on your example shows
D04	0	2450	Wall Line
The mod will still catch W03 as we are using Fence
D04 | W03	0	2450	Wall Line
Unless you move the W03 text a bit down, we can however use WP and include a fuzz value for the points
Message 5 of 13
chauthienqui
Ah I see. That seems the text boundaries of W03 touch the line.
I am understanding like that.
So, I am so happy, it still worked for me. I just need to adjust the way of dratfing
Message 6 of 13
pbejse
All good then
Glad it helps.
Message 7 of 13
chauthienqui
I have just checked, it's pretty funny that when I randomly  made a text wihout any words cross the lwpollyline,
=> The result is no text
Message 8 of 13
pbejse
Interesting, but i didn't really understand what you mean 😀.
A sample drawing on what describe would help.
Message 9 of 13
chauthienqui
That means there is slighlty gap between C and D charater. Even the full text is CD-TI.2.N.1
The lwpoline goes into that slighlty gap, with the algorithm you wrote, it will understand that the text is not on the lwpline.
The result will be like this:
Message 10 of 13
pbejse
I guess we are going to go with this route after all
I'll post the code later @chauthienqui
Message 11 of 13
chauthienqui
Many thanks, you already helped me to deeply understand the code
Message 12 of 13
Sea-Haven
Just a comment, when using ssget "F" it can miss linetypes with gaps as well, changing the variable "LTGAPSELECTION" fixes. Would using ssget "CP" be better method. I add 1st point to end of points list so its closed.
Message 13 of 13
chauthienqui
How could we add 1 more point to selection area without modifying the shape of lwpolyine.?
Would you please guide me to change the code
