Replace circles with Dynamic blocks
Message 1 of 16
Hi all,
I have bunch of circles with two different radiuses (see screenshot below):
They are all on "ASBUILT" layer.
I would like to grab them all by following SSGETs:
(setq ss-lv-poles (ssget "_x" '((-4 . "<or") (-4 . "<and") (0 . "circle") (8 . "ASBUILT") (40 . 0.75) (-4 . "and>") (-4 . "or>")) ) )
(setq ss-Hv-poles (ssget "_x" '((-4 . "<or") (-4 . "<and") (0 . "circle") (8 . "ASBUILT") (40 . 1.7) (-4 . "and>") (-4 . "or>")) ) )
And pass them to a function that I have (Thanks to Lee Mac's useful post) and replace them with a Dynamic block named "Power Pole". The smaller circle should have "Low Voltage Pole" as for its visibility state. Likewise, the double concentric circles should be replaced by same dynamic block with "Low Voltage, High Voltage Pole" visibility state.
Here is my code:
(defun PoleSymbolReplace  (ss1 ss2/ loopLength1 loopLength2 index1 index2 FlagVariable en1 en2 el1 el2 as1 as2)
	(if	(/= ss1 nil)
		(progn
			(setq loopLength1 (sslength ss1))
			(setq index1 0)
			(repeat	loopLength1
				(setq FlagVariable nil)
				(setq en1 (ssname ss1 index))
				(setq el1 (entget en1))
				(setq index1 (+ 1 index1))
				(progn
					(setq as1 (assoc 10 el1))
					(setq xyz (cdr as1))
					(if	(/= ss2 nil)
						(progn
							(setq loopLength2 (sslength ss2))
							(setq index2 0)
							(repeat	loopLength2
								(setq en2 (ssname ss2 index2))
								(setq el2 (entget en2))
								(setq index2 (+ 1 index2))
								(progn
									(setq as2 (assoc 10 el2))
									(if	(equal as1 as2 0.001)
										(progn
											(LM:insertwithstate "Power Pole" "Low Voltage, High Voltage Pole" xyz)
											(entdel en2)
											(entdel en1)
											(setq FlagVariable T)
					(if	(not FlagVariable)
						(progn
							(LM:insertwithstate "Power Pole" "Low Voltage Pole" xyz)
							(entdel en1)
(princ)
But when I call it by:
(PoleSymbolReplace ss-lv-poles ss-Hv-poles)
I get  error: too few arguments
What am I doing wrong here?
Replies (15)
Message 2 of 16
cadffm
old   (defun PoleSymbolReplace  (ss1 ss2/  loopLength1 loopLength2 index1 index2 FlagVariable en1 en2 el1 el2 as1 as2)
want 13 argument
new (defun PoleSymbolReplace  (ss1 ss2 / loopLength1 loopLength2 index1 index2 FlagVariable en1 en2 el1 el2 as1 as2)
want 2 argument
Sebastian
Message 3 of 16
Thanks for the pick up but unfortunately that wasn't the issue 😞
I attached a sample drawing.
Message 4 of 16
cadffm
If that wasnt the issue, that is not your code 😉
But if you fixed that problem and there is a second issue with the same error:
Perhaps it is the unknown function 'LM:insertwithstate', we can not knowing how you defined it.
Sebastian
Message 5 of 16
That was the whole point. I mentioned a link to the Lee's post in my first post. The original code is asking user to select the insertion point. Whereas I tried to change it and pass the insertion coordinates hard-coded instead of asking from user.
(Lee's post is HERE again)
Message 6 of 16
Ranjit_Singh
As written
you need 13 arguments. Add a space between ss2 and /
This may get rid of the too few arguments error.
Message 7 of 16
Hey Ranjit,
Thanks for your reply. I already fixed that missing SPACE in DEFUN.
Program now throws different error:
; error: bad argument type: numberp: nil
No idea why !
Apology to CADffm, I didn't notice the different error message after adding the SPACE character to DEFUN.
Message 8 of 16
Ranjit_Singh
Below works in my minimal testing. Make sure to load all functions from the post you mentioned and also this link
	(if	(/= ss1 nil)
		(progn
			(setq index1 0)
			(repeat	loopLength1
				(setq en1 (ssname ss1 index1))
				(progn
					(if	(/= ss2 nil)
						(progn
							(setq index2 0)
							(repeat	loopLength2
								(progn
										(progn
											(LM:insertwithstate "Power Pole" "Low Voltage, High Voltage Pole")
											(entdel en2)
											(entdel en1)
						(progn
							(LM:insertwithstate "Power Pole" "Low Voltage Pole")
							(entdel en1)
(princ)
Message 9 of 16
Much appreciate it Ranjit.
No error this time but you removed the insertion point (XYZ) from this line:
(LM:insertwithstate "Power Pole" "Low Voltage, High Voltage Pole"  XYZ)
the XYZ variable read in line 13 was supposed to be passed into LM:insertwithstate and stop asking user to select block insertion point.
Am I missing something here? Did it work on your machine with the sample file I provided?
Message 10 of 16
Ranjit_Singh
Have you modified LM:insertwithstate function already to accept 3 arguments? If so, can you provide what you have so far?
Message 11 of 16
Thank you so much Ranjit.
I fixed the problem. Again another bloody SPACE was missing from modified version of Lee's code.
I paste it here in case if anyone else needs it for the same purpose.
All credit goes to Lee Mac (www.lee-mac.com)
Here is the code:
(defun LM:insertwithstate ( blk vis xyz / bse cmd def ent ext new obj pth rtn tmp )
    (setq pth (vl-string-translate "/" "\\" (vl-filename-directory blk))
          ext (cond ((vl-filename-extension blk)) (".dwg"))
          bse (vl-filename-base blk)
    (if (/= "" pth)
        (setq pth (strcat pth "\\"))
    (cond
        (   (not
                (or
                    (and
                        (tblsearch "block" bse)
                        (setq blk bse)
                    (setq blk (findfile (strcat pth bse ext)))
            (prompt (strcat "\nBlock \"" bse "\" not found."))
        (   (progn
                (setq obj
                    (vlax-invoke
                        (vlax-get-property (LM:acdoc)
                            (if (= 1 (getvar 'cvport))
                                'paperspace
                                'modelspace
                        'insertblock
                        '(0.0 0.0 0.0)
                        blk
                        1.0 1.0 1.0 0.0
                (vla-put-visible obj :vlax-false)
                (= :vlax-false (vla-get-isdynamicblock obj))
            (vla-delete obj)
            (prompt (strcat "\nBlock \"" bse "\" is not dynamic."))
        (   (null (LM:setvisibilitystate obj vis))
            (vla-delete obj)
            (prompt
                (strcat
                    "\nUnable to set visibility state of block \""
                    bse
                    "\" to \""
                    vis
        (   (setq tmp 0)
            (while
                (tblsearch "block"
                    (setq blk
                        (strcat "tmp" (itoa (setq tmp (1+ tmp))))
            (vla-put-visible
                (car
                    (vlax-invoke (LM:acdoc) 'copyobjects (list obj)
                        (setq def
                            (vlax-invoke
                                (vla-get-blocks (LM:acdoc))
                                'add
                                '(0.0 0.0 0.0)
                                blk
                :vlax-true
            (vla-delete obj)
            (setq ent (entlast)
                  cmd (getvar 'cmdecho)
            (setvar 'cmdecho 0)
            (if
                (and
                    (vl-cmdf "_.-insert" blk "_S" 1.0 "_R" 0.0 xyz)
                    (not (eq ent (setq ent (entlast))))
                    (setq new (vlax-ename->vla-object ent))
                    (= "AcDbBlockReference" (vla-get-objectname new))
                (progn
                    (setq rtn (car (vlax-invoke new 'explode)))
                    (vla-delete new)
            (setvar 'cmdecho cmd)
            (vl-catch-all-apply 'vla-delete (list def))
    rtn
Message 12 of 16
stevor
1. Looks like LM:insertwithstate should have 2 args, not 3.
2. WHy use dynamic blocks?
S
Message 13 of 16
You are right. That's why I added the third argument to Lee's code.
Dynamic block is what is accepted in the project that I am working on (unfortunately !)
Message 14 of 16
Ranjit_Singh
This seems to work. I am not sure if the results are as expected. You need to verify.
(defun polesymbolreplace  (ss1 ss2 / looplength1 looplength2 index1 index2 flagvariable en1 en2 el1 el2 as1 as2)
  (if (/= ss1 nil)
    (progn (setq looplength1 (sslength ss1))
           (setq index1 0)
           (repeat looplength1
             (setq flagvariable nil)
             (progn (setq as1 (assoc 10 el1))
                    (if (/= ss2 nil)
                      (progn (setq looplength2 (sslength ss2))
                             (setq index2 0)
                             (repeat looplength2
                               (progn (setq as2 (assoc 10 el2))
                                        (progn (lm:insertwithstate "Power Pole" "Low Voltage, High Voltage Pole" xyz)
                                               (entdel en2)
                                               (entdel en1)
                                               (setq flagvariable t)))))))
                    (if (not flagvariable)
                      (progn (lm:insertwithstate "Power Pole" "Low Voltage Pole" xyz) (entdel en1)))))))
  (princ))
Message 15 of 16
braudpat
Hello Ranjit (MAPCAR Jedi Master)
Beautiful Routine and (French Humour) you haven't use MAPCAR ---> Bravo !
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 16 of 16
Ranjit_Singh
@braudpat since mapcar isn't there you can conclude that it isn't my routineSmiley LOL It actually belongs to @Anonymous
