vla-select help
vla-select help
msarqui
vla-select help
msarqui
Hy guys,
Is it possible to use vla-select to select and highlight the previous object?
If yes, how?
Or other method without the "command" because it will be used inside a reactor.
Marcelo
pbejse
@msarqui wrote:
Hy guys,
If yes, how?
Marcelo
There is a fine example shown at AUTODESK KNOWLEDGE NETWORK ---> Select Method
 (vla-Select ssetObj mode corner1 corner2)
    (vlax-for obj   ssetObj
          (vlax-invoke obj 'Highlight T)
What is the intent for highlighting the object msarqui?
msarqui
Hy
Nice to see you again.
when I said "highlight", I was meaning to have the same behaviour when I write on the command line "select" "p"
I want to "see" the grips of the object.
pbejse
@msarqui wrote:
Hy
Hi there, nice to be seen 🙂
AFAICT,  you can use sssetfirst within a reactor to highlight the objects marcelo.
msarqui
You know the kind of thing you already use but not really with full potential?
Thanks!
john.uhden
I know nothing about vla-select, but if you use AutoLisp and create a selection set, like (setq ss (ssget ...)), you can (sssetfirst ss nil) and get exactly what you want.  I use it all the time.  One thing you cannot do with Lisp is to make a grip hot.  I think you need arx to do that.
John F. Uhden
