Regen attribute
- Mute
- Permalink
- Report
The lisp code below does almost everything I want except:
- I want the "regen" command to start with;
- I want to select just 1 one block after selecting the source (so no enter is needed)
Thanks in advantage.
(defun c:MAV (/ AT:GetSel atts ss i ass)
;; Match Attribute Values
;; Alan J. Thompson, 2017.01.31
(defun AT:GetSel (meth msg fnc / ent)
;; meth - selection method (entsel, nentsel, nentselp)
;; msg - message to display (nil for default)
;; fnc - optional function to apply to selected object
;; Ex: (AT:GetSel entsel "\nSelect arc: " (lambda (x) (eq (cdr (assoc 0 (entget (car x)))) "ARC")))
;; Alan J. Thompson, 05.25.10
(while
(progn (setvar 'ERRNO 0)
(setq ent (meth (cond (msg)
("\nSelect object: ")
(cond ((eq (getvar 'ERRNO) 7) (princ "\nMissed, try again."))
((eq (type (car ent)) 'ENAME)
(if (and fnc (not (fnc ent)))
(princ "\nInvalid object!")
ent
(if (and (AT:GetSel entsel
"\nSelect source attributed block: "
(lambda (x / d)
(if (and (eq (cdr (assoc 0 (setq d (entget (car x))))) "INSERT")
(eq (cdr (assoc 66 d)) 1)
(setq atts (mapcar (function (lambda (a) (cons (vla-get-tagstring a) (vla-get-textstring a))))
(vlax-invoke (vlax-ename->vla-object (car x)) 'GetAttributes)
(progn
(princ "\nSelect destination attributed block(s): ")
(setq ss (ssget "_:L" '((0 . "INSERT") (66 . 1))))
(repeat (setq i (sslength ss))
(foreach a (vlax-invoke (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'GetAttributes)
(if (setq ass (cdr (assoc (vla-get-tagstring a) atts)))
(vla-put-textstring a ass)
(princ)
(vl-load-com)
(princ)
