Change 3D Background Color
How to change the 3D background color?
I could not access this property.
Below is the image of the manual change.
dlanorh
(getenv "Parallel background")
(setenv "Parallel background" "15202300")
I am not one of the robots you're looking for
The change until the value of the property happens.
But visually the background of the screen does not change.
I tried REGEN but it still did not work.
dlanorh
(setenv "Parallel background" "255")
I run this in modelspace . This should set the background color to red. If I then go through options-display-colors the 3D parallel background color is now red.
paullimapa
But after setenv you'll have to close & open current dwg & execute vscurrent to see the changed results
Paul Li
IT Specialist
@The Office
