"Revolutionize Your CAD Game: Discover the Ultimate Lisp Hack to Batch Convert Multiple DWG Files into a Single PDF!"
Mohammad_Azaruddin
Mohammad_Azaruddin
Hello everyone,
first of all, sorry for clickbait tittle, this was the only way to grab attention.
I am working on an AutoCAD Electrical project that contains multiple DWG files with different names. I would like to automate the process of publishing the entire project into a single combined PDF. Specifically, I want to publish all the DWG files' model spaces into one PDF that will be saved in the same drawing folder. Can anyone help me build a Lisp program that can accomplish this task?
I am new to lisp programing. I just joined the codes from internet.
I have tried to do it by myself but getting error multiple times "to save pdf pop up" which i do not want. I just want to save my combined pdf to same location as active project. also, I have attached the screenshot which is popping up. I am now frustrated; I want to throw this laptop from my office window.
Any guidance or suggestions would be greatly appreciated.
Thank you in advance for your help!
Mohammad_Azaruddin
the current way to publish is from project manager right click on active project->publish->publish to pdf/dwf->Do all->ok->select your setting from publish setup->OK->PUBLISH->GIVE LOCATION-press OK
so, I want to automate this above process with lisp program if possible.
Thanks.
