3d Polylines to new 2d Polylines on new layer
As-Built_Sigurd
Message 1 of 10
As-Built_Sigurd
Hi Guys,
I started to learn autolisp way back, but have forgotten almost everything and want to write a small program.
Basically, I want to select all 3d polylines which are on the same layer as the one I  select, copy them all to the same position on a new layer (to be created if it doesn't exist). Then the new 3d polylines on the new layer are to be exploded & flattened, then joined to make them 2d polylines.
Is this something I could get to fairly quickly? I have access to fairly basic .lisp functions I could get ideas from.
Sigurd
Replies (9)
Message 2 of 10
paullimapa
start you off with this...see if you can figure out how to place the flattened plines into a new layer
; select 3dpoly to get layer
(while(not(setq en (ssget"_+.:E:S"'((0 . "POLYLINE")(100 . "AcDb3dPolyline"))))))
; get layer name
(setq lyr(cdr(assoc 8(entget (ssname en 0)))))
; select all 3dpolylines on matching layer:
(setq ss(ssget"x"(list'(0 . "POLYLINE")'(100 . "AcDb3dPolyline")(cons 8 lyr))))
; make copy selection to same location
(command"_.Copy" ss "" "@" "@")
; now flatten original selection
(setq selected (sslength ss)) ; get total number of selected objects
(setq ss (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))) ; convert selection of entities to list of vla obj
; flatten selected objects to 1e99 -1e99 which = 0 elevation
(foreach i (list 1e99 -1e99)
 (mapcar(function(lambda (x) (vla-move x (vlax-3d-point (list 0 0 0)) (vlax-3d-point (list 0 0 i))))) ss)
) ; foreach
; echo how many plines flattened
(princ(strcat"\nSuccessfully Flattened [" (itoa selected) "] Plines"))
Paul Li
IT Specialist
@The Office
Message 3 of 10
_gile
You may be inspired by this reply to a similar request at TheSwamp.
Gilles Chanteau
GileCAD
GitHub
Message 4 of 10
Kent1Cooper
There are several approaches to the 3D-to-2D conversion in the Topic containing >this< offering of mine.
Kent Cooper, AIA
Message 5 of 10
As-Built_Sigurd
Hi Paul, thank you for your response.
I've tried to expand on your code with my extremely limited skills :P.
The only problems I have (apart from my very sloppy additions) are:
- I Can't get the new polylines to elevation 0
- Get error message at end but still works
(defun c:3DP2FLATPLBB ()
(command "-linetype" "load" "*" "E:\\Dropbox\\Dropbox\\ABD\\Linetypes\\STREAMBANK" "" "") ;Have to remove parenthesis if linetype exists in drawing
(command "_.Layer" "_Make" "ABD - A - 2d Bank Bottom" "_Color" "251" "" "LType" "STREAMBANK" "" "LWeight" "0.09" "" "")
; get layer name
(command "_chprop" ss "" "_LA" "ABD - A - 2d Bank Bottom" "")
; I should probably setq this layer :P
; select all 3dpolylines on new layer layer:
(setq nl(ssget"x"(list'(0 . "POLYLINE")'(100 . "AcDb3dPolyline")(cons 8 "ABD - A - 2d Bank Bottom"))))
(command "_.AeccConvert3dPolys" nl "")
; Im using Civil 3d so can use this command, but polylines end up on 1st 3dpoly point elevation
Message 6 of 10
As-Built_Sigurd
Oh another problem is that the original 3d polys are usually set to continuous lintypes, and the new 2d polys end up with the same linetypes, rather than bylayer
Message 7 of 10
paullimapa
very good additions you've made.
To test if linetype exists before loading use this code:
(if(not(tblsearch"LTYPE""STREAMBANK"))
Since the Civil3d flatten command does not allow you to place the now 2d Polylines onto 0 elevation, used AutoCAD's built-in Change command:
(command "_.Change" ss "" "_P" "_E" "0" "")
Paul Li
IT Specialist
@The Office
Message 8 of 10
paullimapa
This linetype issue could be caused by the Civil 3D flatten command.
Perhaps try my code I provided before to flatten instead?
) ; foreach
Paul Li
IT Specialist
@The Office
Message 9 of 10
As-Built_Sigurd
Many thanks Paul. Yes putting your flattening code before the conversion to polylines did the trick. I also just added the bylayer bit too. It may look messy, but it works perfectly (as far as I have tested so far).
 (command "-linetype" "load" "*" "E:\\Dropbox\\Dropbox\\ABD\\Linetypes\\STREAMBANK" "" "") ; To check if layer exists
; get layer name
(command "_chprop" ss "" "_LT" "BYLAYER" "")
) ; foreach
; now convert 3d polys
Message 10 of 10
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
