"paint" xref layers as my layer.
sunlight1
sunlight1
HI ALL
i need a lisp that can copy properties from my layers on a xref layer. such as color, linetype, transparency etc
all the properties that show in "layer properties manager" window
all changes will be in my file, and not in the xref file.
it should be like
select layer
get properties
select xref layer
and change layer properties.
i dont mind if the xref keep the layer name or not, it is only for visual in my file, and for easy ctb edit.
tnx for helping me.
ВeekeeCZ
Use LAYTRANS to match the layers.
BTW CTB is kinda obsolete, STB is much more powerful and easier to work with.
sunlight1
sometimes i have 20 layers to change,
instead of searching layers in a list,
the easy way is one click on my layer , and one click on them
i hope that can be possible in a lisp.
ВeekeeCZ
20 layers? Oh boy, I often have 500+ xref layers to maintain. And guess what, with the right STB styles I can do that in just a few mins.
Also, LAYTRANS could save you plenty of time.
But understand, you need a LISP. In that case, HERE is all you need.
Kent1Cooper
Try this [minimally tested]:
(defun C:LPP (/ lay1 layobj1 lay2 layobj2); = Layer Properties Paint [onto another Layer]
  (setq
    lay1 (cdr (assoc 8 (entget (car (nentsel "\nObject on Source Layer for Properties: ")))))
    layobj1 (tblobjname "layer" lay1)
    lay2 (cdr (assoc 8 (entget (car (nentsel "\nObject on Target Layer to Paint Properties on: ")))))
    layobj2 (tblobjname "layer" lay2)
  ); setq
  (foreach prop '("Color" "IsLocked" "IsPlottable" "LineWeight" "LinetypeObjectId" "Transparency")
    (setpropertyvalue layobj2 prop (getpropertyvalue layobj1 prop))
  ); foreach
  (command "_.regen")
  (princ)
); defun
That's in simplest terms, without [yet] verification that you picked something, *error* handling, Undo begin/end wrapping, etc.  There may be other Properties you would want to transfer, or you may not want all those I included.
It works between any Layers, whether either or both or neither is part of an Xref.  BUT be aware that if you pick on something nested in a Block or Xref that at its lowest nesting level was drawn on Layer 0, it will work with Layer 0's Properties, not the apparent Layer of it in its insertion/reference.
Kent Cooper, AIA
sunlight1
TNX A LOT !
im glad we have ppl like u.
tnx again!
