Quick Dimension with fixed spacing from object
Message 1 of 21
 Hi, I`m new here and what I`m going to ask was probably asked before. can you please point me the discussion about dimension with fixed spacing from the object. I`ve been using an LSP that can do that to all sides of a polyline, but I just need to learn or have an LSP that can do that to 1 side only, if possible. thanks a lot.
Replies (20)
Message 2 of 21
devitg
please show your lisp, and sample dwg, with a before and after.
Message 3 of 21
Moshe-A
@Anonymous hi,
if i understand what you want then no automation is need here:
you need to define your dimstyle + set a Fixed length extension lines length (and make it current)
then use DIMLIN or DIMALI commands and use <select object> option (just by hitting enter) and the rest autocad will do - NO?
moshe
Message 4 of 21
Thanks for the reply, much appreciated.
I've been using this LSP (Dimpoly.lsp) I got which I forgot where, CTTO, and it's been helping me a lot.
It put dimensions in all sides of a selected object with fixed location.
But there are instances which I just need to quickly put a dimension in 1 side,
just like in my attached photo.
There's also this AD.lsp (ctto), it could have done what I wanted but it needed the spacing/location to be
indicated every time, which is a bit troublesome.
Is there a way this could be set 1 time and modify as per drawing standard.
Thanks in advance.
Message 5 of 21
devitg
Message 6 of 21
I already attached a sample drawing and the LSP I am using in my previous reply.
Message 7 of 21
DimPoly.lsp
;;  DimPoly.lsp [command names: DPI = Dimension Polyline(s) Inside, DPO = Outside]
;;  To dimension the lengths of all segments of selected Polylines on the Inboard or
;;    Outboard side.  For self-intersecting or open Polyline without a clear "inside" and
;;    "outside," will determine a side -- if not as desired, undo and run other command.
;;  Dimensions along arc segments will be angular Dimensions, showing length of arc
;;    as text override, not included angle native to angular Dimensions.  They will not
;;    update if Polyline is stretched, as those along line segments will; redo DPI/DPO.
;;  Uses current Dimension and Units settings; dimension line location distance from
;;    Polyline segment = 1.5 x dimension text height for stacked fractions to clear [see
;;    commentary at setting of dtxt variable re: stacked fractions].
;;  Accepts LW and 2D "heavy" Polylines, but not 3D Polylines or meshes.  Rejects any
;;    on locked Layers, because of Offset used to determine inside/outside.
;;  Kent Cooper, last edited 18 May 2016
(vl-load-com)
(defun DP (side / *error* doc svnames svvals styht dpss n pl cw inc pt1 pt3 pt2 ang1 ang2 dtxt pt4)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    ); if
    (mapcar 'setvar svnames svvals); reset System Variables
    (vla-endundomark doc)
    (princ)
  ); defun -- *error*
  (vla-startundomark (setq doc (vla-get-activedocument (vlax-get-acad-object))))
  (setq ; System Variable saving/resetting without separate variables for each:
    svnames '(osmode cmdecho blipmode clayer)
    svvals (mapcar 'getvar svnames)
  ); setq
  (mapcar 'setvar svnames '(0 0)); turn off Osnap, command echoing
  (command "_.layer" "_make" "ST-DIM" "_color" 8 "" "");; <---EDIT Layer name/color as desired
  (setq styht (cdr (assoc 40 (tblsearch "style" (getvar 'dimtxsty))))); height of text style in current dimension style
  (if (= styht 0.0) (setq styht (* (getvar 'dimtxt) (getvar 'dimscale)))); if above is non-fixed-height
  (prompt (strcat "\nTo Dimension Polyline(s) on the " side "side,"))
  (if (setq dpss (ssget "_:L" '((0 . "*POLYLINE"))))
    (progn ; then [can omit this if you never use blips; also two other lines below]
      (setvar 'blipmode 0); [omit if you never use blips and omitted line above]
      (repeat (setq n (sslength dpss)); step through selection set
        (setq pl (ssname dpss (setq n (1- n))))
        (if (= (logand (cdr (assoc 70 (entget pl))) 88) 0)
          ;; not 3D or mesh [88 = 8 (3D) + 16 (polygon mesh) + 64 (polyface mesh)]
          (progn ; then
            (setq pl (vlax-ename->vla-object pl))
            (vla-offset pl styht); temporary
            (setq cw (< (vla-get-area (vlax-ename->vla-object (entlast))) (vla-get-area pl)))
              ;; clockwise for closed or clearly inside/outside open; may not give
              ;; desired result for open without obvious inside/outside
            (entdel (entlast))
            (repeat (setq inc (fix (vlax-curve-getEndParam pl))); segments
              (setq
                pt1 (vlax-curve-getPointAtParam pl inc)
                pt3 (vlax-curve-getPointAtParam pl (1- inc))
              ); setq
              (if (not (equal pt1 pt3 1e-8)); not coincident vertices
                (progn ; then -- proceed to dimension segment
                  (setq
                    pt2 (vlax-curve-getPointAtParam pl (- inc 0.5)); segment midpoint
                    ang1 (angle pt1 pt2)
                    ang2 (angle pt2 pt3)
                  ); setq
                  (if
                    (or ; line segment?
                      (equal ang1 ang2 1e-8); any non-0 direction or both reading as 0 or 2 pi
                      (equal (abs (- ang2 ang1)) (* pi 2) 1e-8); 0-degree with one reading as 2 pi +/-
                    ); or
                    (command "_.dimaligned" pt1 pt3); then [leaves at dimension line location prompt]
                    (progn ; else [arc segment]
                      (setq dtxt
                        (rtos
                          (abs ; length along arc segment
                            (- (vlax-curve-getDistAtParam pl inc) (vlax-curve-getDistAtParam pl (1- inc)))
                          ); abs
                          ;; [include mode/precision here if current dimension style's settings not desired]
                        ); rtos
                      ); setq
                      (if (wcmatch dtxt "*/*"); includes fraction?
                        ;; can omit this entire (if) function if you don't use stacked fractions
                        (setq dtxt ; stack it
                          (strcat
                            "\\A1;"
                            (vl-string-subst ";}\"" "\""
;                              (vl-string-subst "#" "/"
                                ;; remove ; from beginning of above line and its closing parenthesis line
                                ;; below to make diagonal stack [makes horizontal-line stack without]
                                (vl-string-subst "{\\H0.875x;\\S" " " dtxt)
                                  ;; change 0.875 ratio to agree with Dimension Style's setting
;                              ); -subst
                            ); -subst
                          ); strcat & dtxt
                        ); setq
                      ); if
                      (command
                        "_.dimangular" ""
                        (inters ; arc center
                          (setq pt4 (mapcar '/ (mapcar '+ pt1 pt2) '(2 2 2)))
                          (polar pt4 (+ (angle pt1 pt2) (/ pi 2)) 1)
                          (setq pt4 (mapcar '/ (mapcar '+ pt2 pt3) '(2 2 2)))
                          (polar pt4 (+ (angle pt2 pt3) (/ pi 2)) 1)
                          nil
                        ); inters
                        pt1 pt3
                        "_text" dtxt
                      ); command [leaves at dimension line location prompt]
                    ); progn
                  ); if
                  (command ; complete Dimension: dimension line location
                    (polar
                      pt2
                      (apply ; angle
                        (if (or (and cw (= side "in")) (and (not cw) (= side "out"))) '- '+)
                        (list
                          (angle '(0 0 0) (vlax-curve-getFirstDeriv pl (- inc 0.5)))
                          (/ pi 2)
                        ); list
                      ); apply
                      (* styht 3.125); distance
                        ;; [If you don't use stacked fractions, consider using styht without multiplier]
                    ); polar
                  ); command
                ); progn
              ); if [not coincident]
              (setq inc (1- inc))
            ); repeat [segments]
          ); progn -- then [LW/2D]
        ); if
      ); repeat [Polylines]
    ); progn -- then [valid selection]; [omit if you never use blips and omitted 2 lines above]
    (prompt "\nNo Polyline(s) on unlocked Layer(s) selected."); else
  ); if
  (princ)
); defun -- DP
(defun C:DPI () (DP "in")); = Dimension Polyline Inside
(defun C:DPO () (DP "out")); = Dimension Polyline Outside
(prompt "\nType DPI to Dimension Polyline(s) on the Inside, DPO to do so on the Outside.")
Message 8 of 21
AD.lsp
(defun c:AD (/ p1 p2 p3 Udist)
      (setq udist (getreal "\nOffset Distance :"))
      (setq p1 (getpoint "\n Specify first extension line origin :"))
      (setq p2 (getpoint "\n Specify first extension line origin :"))
      (setq P3 (polar P2 (+ (angle p1 p2)(/ pi 2)) udist))
      (command "_.dimaligned" "_non" p1 "_non" p2 "_m" "" P3)
(while
  (princ)
Message 9 of 21
Moshe-A
@Anonymous  hi,
this lisp does noting more than DIMLIN \ DIMALI standard AutoCAD commands. when you will have time, explore "Fixed length extension lines length" on DIMSTYLE and you will see what i'm talking about.
Message 10 of 21
kibitotato
I like this lisps. Im wondering about having the AD.lsp with a prefixed distance like DPI DPO... Is it possible?
Message 11 of 21
kibitotato
I tried to do by myself by I doesnt works...
(setq udist (getreal "\nOffset Distance :" ss "0,15"))
(while
(princ)
Message 12 of 21
ВeekeeCZ
Is this what you want to have?
(defun c:AD10 (/ p1 p2 p3 Udist)
  (setq udist 10)
  (while
  (princ)
Message 13 of 21
kibitotato
exactly thanks
Message 14 of 21
ahmadshabrawy_98
I would like to edit this lisp to ask me about the distance from the object
here is the lisp
; Program Name: AutoDPL - Dimension Polylines
; Created By: https://www.youtube.com/@CivilSurvey/featured
; Function: Dimensions Polyline shapes
; Revision History
; Rev By Date Description
; 1 TM 5-20-08 Initial version
; c:autoDPL - Dimensions Polyline
(defun c:AutoDPL (/ EntName^ EntPick@)
(setvar "CMDECHO" 0)
(if (setq EntPick@ (entsel "\nSelect Polyline to dimension: "))
(if (= (cdr (assoc 0 (entget (car EntPick@)))) "LWPOLYLINE")
(progn
(setq EntName^ (cdr (assoc -1 (entget (car EntPick@)))))
(DimPL EntName^)
);progn
);if
);if
(if (not EntName^)
(princ "\nNo Polyline selected.")
);if
(princ)
);defun c:DPL
; DimPL - Function to dimension Polyline
; Arguments: 1
; EntName^ = Polyline entity name
; Returns: Dimensions Polyline
(defun DimPL (EntName^ / Bottom@ Clayer$ CW# DiffAng DimPts: DimSpace~ EntList@
Item LastAng~ LastPt Left@ List@ NW@ Osmode# P0 P1 P2 Pt Pts@ PtsLen Right@ SE@
Top@ X~ X1~ X1Y1 X1Y2 X1Ys@ X2~ X2Y1 X2Y2 X2Ys@ XPts@ Y~ Y1~ Y1X1 Y1X2 Y1Xs@ Y2~
Y2X1 Y2X2 Y2Xs@ YPts@)
(defun DimPts: (Pts@ StartPt EndPt Type$ / Add Num1~ Num2~ Nums1@ Nums2@ P1 P2
Pt Return@)
(setq Add t)
(foreach Pt (member StartPt (append Pts@ Pts@))
(if Add
(setq Return@ (append Return@ (list Pt)))
);if
(if (equal Pt EndPt)
(setq Add nil)
);if
);foreach
(foreach Pt Return@
(if (member Type$ (list "Left" "Right"))
(setq Nums1@ (append Nums1@ (list (cadr Pt))))
(setq Nums1@ (append Nums1@ (list (car Pt))))
);if
);foreach
(foreach Num1~ (vl-sort Nums1@ '<)
(setq Nums2@ nil)
(foreach Pt Return@
(if (= (cadr Pt) Num1~)
(setq Nums2@ (append Nums2@ (list (car Pt))))
);if
(if (= (car Pt) Num1~)
(setq Nums2@ (append Nums2@ (list (cadr Pt))))
);if
);if
);foreach
(if (member Type$ (list "Left" "Bottom"))
(setq Nums2@ (vl-sort Nums2@ '<))
(setq Nums2@ (reverse (vl-sort Nums2@ '<)))
);if
(foreach Num2~ (cdr Nums2@)
(setq Pt (list Num2~ Num1~))
(setq Pt (list Num1~ Num2~))
);if
(setq Return@ (vl-remove Pt Return@))
);foreach
);foreach
(cond
((= Type$ "Left")
(vl-sort Return@ (function (lambda (P1 P2)(< (cadr P1)(cadr P2)))))
);case
((= Type$ "Top")
(vl-sort Return@ (function (lambda (P1 P2)(< (car P1)(car P2)))))
);case
((= Type$ "Right")
(vl-sort Return@ (function (lambda (P1 P2)(> (cadr P1)(cadr P2)))))
);case
((= Type$ "Bottom")
(vl-sort Return@ (function (lambda (P1 P2)(> (car P1)(car P2)))))
);case
);cond
);defun DimPts:
(setq EntList@ (entget EntName^))
(if (= (cdr (assoc 0 EntList@)) "LWPOLYLINE")
(progn
(foreach List@ EntList@
(if (= (car List@) 10)
(if (not (equal (cdr List@) LastPt))
(progn
(setq Pts@ (append Pts@ (list (cdr List@))))
(if (> (length Pts@) 2)
(if (/= (angle LastPt (cdr List@)) LastAng~) (setq DiffAng t))
);if
(if (> (length Pts@) 1)
(setq LastAng~ (angle LastPt (cdr List@)))
);if
(setq LastPt (cdr List@))
);progn
);if
);if
);foreach
(if (equal (car Pts@) (last Pts@))
(setq Pts@ (reverse (cdr (reverse Pts@))))
);if
(setq PtsLen (length Pts@))
);progn
(exit)
);if
(foreach Pt Pts@
(setq X~ (atof (rtos (car Pt) 2 8))
Y~ (atof (rtos (cadr Pt) 2 8))
XPts@ (append XPts@ (list X~))
YPts@ (append YPts@ (list Y~))
Pts@ (cdr (append Pts@ (list (list X~ Y~))))
);setq
);foreach
(setq XPts@ (vl-sort XPts@ '<)
YPts@ (vl-sort YPts@ '<)
X1~ (car XPts@)
X2~ (last XPts@)
Y1~ (car YPts@)
Y2~ (last YPts@)
);if
(foreach Pt Pts@
(if (= (car Pt) X1~) (setq X1Ys@ (append X1Ys@ (list (cadr Pt)))))
(if (= (car Pt) X2~) (setq X2Ys@ (append X2Ys@ (list (cadr Pt)))))
(if (= (cadr Pt) Y1~) (setq Y1Xs@ (append Y1Xs@ (list (car Pt)))))
(if (= (cadr Pt) Y2~) (setq Y2Xs@ (append Y2Xs@ (list (car Pt)))))
);foreach
(setq X1Ys@ (vl-sort X1Ys@ '<)
X2Ys@ (vl-sort X2Ys@ '<)
Y1Xs@ (vl-sort Y1Xs@ '<)
Y2Xs@ (vl-sort Y2Xs@ '<)
X1Y1 (list X1~ (car X1Ys@))
X1Y2 (list X1~ (last X1Ys@))
X2Y1 (list X2~ (car X2Ys@))
X2Y2 (list X2~ (last X2Ys@))
Y1X1 (list (car Y1Xs@) Y1~)
Y1X2 (list (last Y1Xs@) Y1~)
Y2X1 (list (car Y2Xs@) Y2~)
Y2X2 (list (last Y2Xs@) Y2~)
Pts@ (member X1Y1 (append Pts@ Pts@))
);setq
(while (> (length Pts@) PtsLen)
);while
(setq SE@ (member X2Y2 Pts@) NW@ Pts@)
(foreach Item SE@
(setq NW@ (vl-remove Item NW@))
);foreach
(setq SE@ (append SE@ (list X1Y1))
NW@ (append NW@ (list X2Y2))
CW# 0
);setq
(foreach Pt (list Y2X1 Y2X2)
(if (member Pt NW@) (setq CW# (1+ CW#)))
(if (member Pt SE@) (setq CW# (1- CW#)))
);foreach
(foreach Pt (list Y1X1 Y1X2)
(if (member Pt SE@) (setq CW# (1+ CW#)))
(if (member Pt NW@) (setq CW# (1- CW#)))
);foreach
(if (< CW# 0)
(setq Pts@ (append (list (car Pts@))(reverse (cdr Pts@))))
);if
(setq Left@ (DimPts: Pts@ Y1X1 Y2X1 "Left"))
(setq Top@ (DimPts: Pts@ X1Y2 X2Y2 "Top"))
(setq Right@ (DimPts: Pts@ Y2X2 Y1X2 "Right"))
(setq Bottom@ (DimPts: Pts@ X2Y1 X1Y1 "Bottom"))
(command "UNDO" "BEGIN")
(setq DimSpace~ (* (getvar "DIMSCALE") (getvar "DIMTXT") 3))
(setq Osmode# (getvar "OSMODE")) (setvar "OSMODE" 0)
(setq Clayer$ (getvar "CLAYER"))
(command "LAYER" "S" (GetDimLayer) "");<--Change to your Dim layer info
(setq P0 (polar X1Y1 pi (* DimSpace~ 1.5))
P1 (car Left@)
);setq
(foreach P2 (cdr Left@)
(command "DIM1" "VER" P1 P2 P0 "")
(setq P1 P2)
);foreach
(if (> (length Left@) 2)
(progn
(setq P0 (polar P0 pi DimSpace~))
(command "DIM1" "VER" (car Left@) (last Left@) P0 "")
);progn
);if
(setq P0 (polar Y2X1 (* pi 0.5) (* DimSpace~ 1.5))
P1 (car Top@)
);setq
(foreach P2 (cdr Top@)
(command "DIM1" "HOR" P1 P2 P0 "")
(setq P1 P2)
);foreach
(if (> (length Top@) 2)
(progn
(setq P0 (polar P0 (* pi 0.5) DimSpace~))
(command "DIM1" "HOR" (car Top@) (last Top@) P0 "")
);progn
);if
(setq P0 (polar X2Y2 0 (* DimSpace~ 1.5))
P1 (car Right@)
);setq
(if (and (> (length Right@) 2) DiffAng)
(foreach P2 (cdr Right@)
(setq P1 P2)
);foreach
);if
(setq P0 (polar Y1X2 (* pi 1.5) (* DimSpace~ 1.5))
P1 (car Bottom@)
);setq
(if (and (> (length Bottom@) 2) DiffAng)
(foreach P2 (cdr Bottom@)
(setq P1 P2)
);foreach
);if
(setvar "CLAYER" Clayer$)
(setvar "OSMODE" Osmode#)
(command "UNDO" "END")
(princ)
);defun DimPL
; GetDimLayer - Returns the layer name that's on and has the most dimensions,
; or the current layer name if there's no dimensions.
(defun GetDimLayer (/ DimLayer$ EntList@ Index# Layer$ LayerInfo@ LayerList@ List@ Num# SS&)
(setq Layer$ (getvar "CLAYER"))
(if (setq SS& (ssget "X" '((0 . "DIMENSION"))))
(progn
(setq Index# -1)
(while (< (setq Index# (1+ Index#)) (sslength SS&))
(setq EntList@ (entget (ssname SS& Index#))
DimLayer$ (cdr (assoc 8 EntList@))
LayerInfo@ (tblsearch "LAYER" DimLayer$)
);setq
(if (and (= (cdr (assoc 70 LayerInfo@)) 0)(> (cdr (assoc 62 LayerInfo@)) 0))
(if (assoc DimLayer$ LayerList@)
(setq Num# (1+ (cdr (assoc DimLayer$ LayerList@)))
LayerList@ (subst (cons DimLayer$ Num#) (assoc DimLayer$ LayerList@) LayerList@)
);setq
(setq LayerList@ (append LayerList@ (list (cons DimLayer$ 1))))
);if
);if
);while
(if LayerList@
(progn
(setq Layer$ (car (car LayerList@))
Num# (cdr (car LayerList@))
);setq
(foreach List@ (cdr LayerList@)
(if (> (cdr List@) Num#)
(setq Layer$ (car List@)
Num# (cdr List@)
);setq
);if
);foreach
);progn
);if
);progn
);if
Layer$
);defun GetDimLayer
(princ);End of DPL.lsp
Message 15 of 21
kibitotato
Doesn´t work for me because my Autocad is in Spanish...
Comando: AUTODPL
Select Polyline to dimension: Comando "UNDO" desconocido. Pulse F1 para obtener ayuda.
Comando "BEGIN" desconocido. Pulse F1 para obtener ayuda.
Comando "S" desconocido. Pulse F1 para obtener ayuda.
Comando "1-BAS-LIN" desconocido. Pulse F1 para obtener ayuda.
Comando "AUTODPL" desconocido. Pulse F1 para obtener ayuda.
Comando "END" desconocido. Pulse F1 para obtener ayuda.
Message 16 of 21
komondormrex
check the mod there
Message 17 of 21
kibitotato
It works for me bur it only works with geometris aligned to X Y axis... Is it posible to have the same thing but aligned with the pline?
Message 18 of 21
komondormrex
like what?
Message 19 of 21
kibitotato
1 your definition
2 what I want
Message 20 of 21
komondormrex
check the following. dimizes lwpline using current dimstyle. positive dimension offset sets dimension outwards of pline, negative - inwards, zero - along the pline.
;	komondormrex, oct 2023
(defun c:dimize_pline (/ command_terminated dim_offset pline_object next_param param_list bulge_list segment_list segment_start segment_end segment_middle segment_bulge
						 dim_object center_point
	(defun get_prompted_value (initget_value get_function prompt_string var command_terminated / default_string var_saved)
		(if (/= 3 (getvar 'dynmode)) (setvar 'dynmode 3))
		(if (null command_terminated)
			(progn
				(setq var_saved (read (strcat (vl-symbol-name var) "_saved")))
				(cond
						(null (vl-symbol-value var_saved))
							(setq default_string "")
						(= 'str (type (vl-symbol-value var_saved)))
							(setq default_string (vl-symbol-value var_saved))
						t
							(setq default_string (rtos (vl-symbol-value var_saved)))
				(initget initget_value)
	 			(set var (vl-catch-all-apply get_function (list (strcat "\n" prompt_string " <" default_string ">: "))))
	 			(cond
						(or
							(null (vl-symbol-value var))
							(= "" (vl-symbol-value var))
	 						(set var (vl-symbol-value var_saved))
	 					(vl-catch-all-error-p (vl-symbol-value var))
	 						(setq command_terminated t)
	 					t
	 						(set var_saved (vl-symbol-value var))
	 	command_terminated
	(defun arc_segment_center (bulge start_point end_point / arc_segment_direction half_included_angle center_position center_distance arc_segment_center )
		(setq arc_segment_direction (/ bulge (abs bulge))
			  half_included_angle (* 2.0 (atan (abs bulge)))
			  center_position (cond
										(< pi (* 2.0 half_included_angle))
											(setq center_distance (/ (* 0.5 (distance start_point end_point)) (/ (sin (- pi half_included_angle)) (cos (- pi half_included_angle)))))
											-1.0			;	center point inside arc
										(> pi (* 2.0 half_included_angle))
											(setq center_distance (/ (* 0.5 (distance start_point end_point)) (/ (sin half_included_angle) (cos half_included_angle))))
											+1.0            ;	center point outside arc
										t
											(setq center_distance 0.0)
											 0.0            ;	center point halfway from arc start poit to arc end point
			  arc_segment_center (polar (polar start_point (angle start_point end_point) (* 0.5 (distance start_point end_point)))
			  							(+ (angle start_point end_point) (* arc_segment_direction center_position 0.5 pi))
										center_distance
	(defun find_pline_direction (segment_list pline_object / angle_list)
		(defun diff_angle (angle_1 angle_2)
		  	(setq angle_1 (if (> angle_2 (+ pi angle_1)) (+ (* pi 2) angle_1) angle_1))
		  	(setq angle_2 (if (> angle_1 (+ pi angle_2)) (+ (* pi 2) angle_2) angle_2))
		  	(- angle_2 angle_1)
		(setq angle_list (mapcar '(lambda (segment) (angle (vlax-curve-getpointatparam pline_object (car segment))
		  												   (vlax-curve-getpointatparam pline_object (cadr segment))
				 	  			  segment_list
		(if (> (apply '+ (mapcar '(lambda (angle_1 angle_2) (diff_angle angle_1 angle_2)) angle_list (cdr angle_list))) 0) t nil)
	(if (not (minusp (vlax-get (vla-get-activelayer (vla-get-activedocument (vlax-get-acad-object))) 'lock)))
			(progn
				(vla-startundomark (vla-get-activedocument (vlax-get-acad-object)))
				(if (null dim_offset_saved) (setq dim_offset_saved 10))
				(and
					(or
						(null (get_prompted_value 0 'getdist "Dimension offset:" 'dim_offset command_terminated))
						(null (princ "\nCommand cancelled"))
					(repeat (sslength (setq ename_index -1
											ignore_empty_sset (while (null (setq pline_sset (vl-catch-all-apply 'ssget (list '((0 . "lwpolyline")))))))
											pline_sset (cond
																		(vl-catch-all-error-p pline_sset)
																			(ssadd)
																		t
																			pline_sset
							(setq pline_object (vlax-ename->vla-object (ssname pline_sset (setq ename_index (1+ ename_index))))
								  next_param -1
								  param_list nil
								  bulge_list nil
							(repeat (fix (vlax-curve-getendparam pline_object))
								(setq param_list (append param_list (list (setq next_param (1+ next_param))))
									  bulge_list (append bulge_list (list (vla-getbulge pline_object next_param)))
							(setq segment_list (mapcar '(lambda (param next_param bulge) (list param next_param bulge))
														param_list
														(append (cdr param_list) (list (1+ (last param_list))))
														bulge_list
							(if (find_pline_direction segment_list pline_object) (setq modify_angle '-) (setq modify_angle '+))
							(foreach segment segment_list
								(setq segment_start (vlax-curve-getpointatparam pline_object (car segment))
									  segment_end (vlax-curve-getpointatparam pline_object (cadr segment))
									  segment_middle (vlax-curve-getpointatparam pline_object (* 0.5 (+ (car segment)(cadr segment))))
									  segment_bulge (last segment)
								(cond
										(zerop segment_bulge)
											(setq dim_object (vla-adddimaligned (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
														   						(vlax-3d-point segment_start)
														   						(vlax-3d-point segment_end)
														   						(vlax-3d-point (polar segment_middle
																									  ((eval modify_angle) (angle segment_start segment_end) (* 0.5 pi))
																									  dim_offset
										t
											(setq center_point (arc_segment_center segment_bulge segment_start segment_end))
											(setq dim_object (vla-adddimarc (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
																 			(vlax-3d-point center_point)
																			(vlax-3d-point (polar segment_middle ((eval modify_angle) (angle segment_start segment_end) (* 0.5 pi)) dim_offset))
			(vla-endundomark (vla-get-activedocument (vlax-get-acad-object)))
		(alert "       Active layer is locked")
	(princ)
