command not consistent (pt is never the same)
lemoinemarc
lemoinemarc
Hi, I'm trying to figure out why a command I made will work sometimes and sometimes will not..I suspect a pt that is not clearing from an other command, but i made sure to include all the variables on the defun line..This is the only function that has this behavior (out of 33)
Maybe I don't use the cad,cadr,caddr like I should?
(defun c:base01 ( / pt1 pt2 pt4 a1 a2 a3 a4 );base de ciment fenetre
(command "-layer" "make" "00" "" )
(command "ucs" "w" )
(setq pt1 (getpoint))
(setq pt2 (list (car pt1) (cadr pt1) (- (caddr pt1 9))
(setq pt4 (list (car pt1) (cadr pt1) (- (caddr pt1 2))
(command "solidedit" "f" "c" pause "" pt1 pt1 "x" "")
(setq a1 (entlast))
(command "extrude" a1 "" "-2" )
(setq a2 (entlast))
(command "erase" a1 "")
(command "isolateobjects" a2 "" )
(command "solidedit" "f" "o" pause "all" "" "1" "" "" )
(command "unisolateobjects" )
(command "slice" a2 "" "xy" pt4 "0,0,2000" )
(setq a3 (entlast))
(command "slice" a3 "" "xy" pt1 "0,0,-1000" )
(setq a4 (entlast))
(command "chprop" a4 "" "layer" "ciment" "")
(princ)
Kent1Cooper
Do you sometimes have running Object Snap modes in effect?  Does it work correctly when you do not?
Kent Cooper, AIA
lemoinemarc
I think you are on to something..
  • I positioned a solid so that a top corner is at 0,0,0
  • I disabled Osnap and instead of choosing pt1 with the mouse, i entered 0,0,0
  • the function did it's thing and it worked everytime!
So I guess Disabling Osmode after the pt1 selection? I tried this but it won't work:
(defun c:base02 (/ pt1 pt2 pt4 a1 a2 a3 a4 );base de ciment fenetre
(setvar "osmode" 0)
(setq pt2 (list (car pt1) (cadr pt1) (+ (caddr pt1) 9)))
(setq pt4 (list (car pt1) (cadr pt1) (+ (caddr pt1) 4)))...
lemoinemarc
Oups! it works now..I accidentally removed a bracket so it wouldn't load.
As for the solution, I didn't know that Osnap would still work during a function. I understand now that the reason it worked sometimes was that I zoomed enough so that it wouldn't snap to anything else..
thank you! 🙂
Kent1Cooper
@lemoinemarc wrote:
.... I didn't know that Osnap would still work during a function. ….
It works during a (command) function when it's asking for a point.  This is one reason some prefer to draw things with (entmake) instead, when practical, because Osnap doesn't affect the results.  But when there are only a few points to deal with in a routine, it can also be controlled without turning off Osnap by putting "_none" Osnap calls before point entries.
Kent Cooper, AIA
cadffm
It's also still  working by type in the coords into commandline by hand!
A) by hand
B) in automation like macro/script/lisp.. (when then command or function ask for Userinput)
C) both
Controlled by one of 1000 options/Variables. Read this - click!
Or just OPTIONS/User preferences/  [Priority for coordinate...]
Sebastian
