LISP Help
LISP Help
Tolearnlisp
Message 1 of 9
LISP Help
Tolearnlisp
Hi fellows,
would like to have a lisp that create automatic line from center of a square to the center of a circle respectively just by selecting the square and circle after the Lisp command. Thanks in advance.
Replies (8)
Message 2 of 9
ennujozlagam
hello, you can refer these LINK and LINK. thanks
Message 3 of 9
RobDraw
Why LISP for such a simple thing as this?
Rob
Message 4 of 9
Erense
I would advise a Dynamic block with a stretch action between the square and the circle.
Probably much easier than a lisp routine.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Edwin Rense
Cadac Group AEC BV
Supporting Consultant AEC
Cadac Group .
Message 5 of 9
Kent1Cooper
Two threads on the same topic are not a good idea.  If a solution is found in one, and someone finds the other in looking for a similar thing, they won't know there's a solution.
Carry on in >the other thread<, which at least has a somewhat more descriptive Title.
Kent Cooper, AIA
Message 6 of 9
Tolearnlisp
Hi ennujozlagam,
Thank you for the links below, I am thinking of merging the LISP.
Message 7 of 9
Tolearnlisp
Hi RobDraw,
Thank you. I came to the Idea of asking this kind of lisp because it will be very usefull and fast in doing a hundreds of boxes and circles by just selecting the oject then the line will connect them.
Message 8 of 9
Tolearnlisp
Hi Erense,
Thank you. I am looking this kind of lisp because it will be very helpful and easy by just selecting the circle and rectangle and it will create the line automatically. We've been doing hundreds of object, the size, the location are all variables.
Message 9 of 9
Tolearnlisp
Hi Kent1Cooper,
Thank you and I appreciate.
