Question about Get Dynamic Block Visibility State - Lee Mac
S_S_SS
S_S_SS
Hello every one
I get this code from lee mac website
can some one explain more about using this code
I have a block and it's name is "Sbeam 12 cm variable length
and I have a visibility parameter called "Visibility1"
and I need the lisp to give me the name of the visibility state of all of the blocks in a table
I'll upload the DWG
;; Get Dynamic Block Visibility State  -  Lee Mac
;; Returns the value of the Visibility Parameter of a Dynamic Block (if present)
;; blk - [vla] VLA Dynamic Block Reference object
;; Returns: [str] Value of Visibility Parameter, else nil
(defun LM:getvisibilitystate ( blk / vis )
    (if (setq vis (LM:getvisibilityparametername blk))
        (LM:getdynpropvalue blk vis)
THANKS IN ADVANCE
ВeekeeCZ
@S_S_SS wrote:
Hello every one
I'll upload the DWG
THANKS IN ADVANCE
Look at the code, do you really think that it's so simple?
The red are functions of which you need definitions.
Sea-Haven
A very quick answer
(setq ss (ssget (list (cons 0 "INSERT")(cons 2 "*u*"))))
(setq lst '())
(repeat (setq x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
(setq lst (cons (list (vla-get-name obj)(LM:getvisibilitystate obj)) lst))
 make it a defun
Does this mean have to redo the schedule of quantities again ? Private emails.
