Calling a lisp routine with an argument from command line or menu/button.
PDACTL
PDACTL
I have a series of lisp functions for layer manipulation in the form:
(defun c:YY_LAYnn ()
  ;do stuff here with LAYnn
where the code is identical but for the layer name.
I would like a single generic function where the layer name is passed as an argument, like so:
(defun c:YY ( LAYnn )
How would I invoke this from the command line or toolbar button?
cadffm
hi
it isn't usefull to use a name starting with "c:", starting with "c:" defines an AutoCAD-command call for functions without arguments.
(it also works with a c: like "c:myfunc" but you can not use them as AutoCAD-Command, so get rid of the "c:" part)
(defun YY ( LAYnn )
>>"How would I invoke this from the command line or toolbar button?"
(YY "MyLayerName")
Sebastian
PDACTL
That sorted it. Thank you!
I now have a different syntax problem.
In the following situation where entities have their linetypes amended...
(defun ChangeLinetype( nnn )
(IF (/= nil (SETQ EN (SSGET)))
(PROGN
(SETQ C 0)
(WHILE (< C (SSLENGTH EN))
(PROGN
(entmod (append (ENTGET (SSNAME EN C)) '((6 . "GHOST"))))
(SETQ C (+ C 1))
I want to replace "GHOST" with whatever the argument nnn is.
How do I do this?
ВeekeeCZ
If it could be loaded from the default *.lin.
(defun ChangeLinetype ( nnn / s i)
  (or (tblsearch "ltype" nnn)
      (command "_.-LINETYPE" "_L" nnn "" "")
  (if (setq s (ssget "_:L"))
    (repeat (setq i (sslength s))
      (entmod (append (entget (ssname s (setq i (1- i)))) (list (cons 6 nnn))))))
  (princ)
PDACTL
(list (cons 6 nnn))
This was the bit I needed. Thanks.
Sea-Haven
Expanding the beekeecz solution, the multi getvals.lsp could be used as it will allow one entry and is only a few line of code as the core code is loaded as required.
(defun c:ChangeLinetype ( / s i nnn)
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq nnn (car (AH:getvalsm (list "Enter layer " "Layer " 20 19  "Continuous"))))
  (princ)
(c:changelinetype)
if you do this a lot look at a menu or use AUTOLOAD in a startup lisp.
 Multi getvals.lsp must be saved in a support path.
