Put hatch grips on grid
^_^clovis^_^
^_^clovis^_^
I'm writing a small routine to put entities on a defined grid. I can't figure out how to change a hatch grips using lisp. Any help would be greatly appreciated!
ВeekeeCZ
There is no specific grip functionality in lisp such could be... (gripmove p1 p2)
You need to modify the boundary definition somehow eg. (getpoint) > (entmode)
Or post the code and explain your goal....
Kent1Cooper
You can use the commands in zzQUANTIZE.lsp, available >here<.  If the Hatch pattern is associative, use a Quantizing command on what it's associated with, and it will follow.  If not, use it on the Hatch pattern itself.
Kent Cooper, AIA
^_^clovis^_^
Thanks for your input and sharing your routine.
using your routine is faster than using the boundaries->recreate.
I hope that the grips will be available/reachable with lisp in the future.
