Purge Unused Raster Image Reference
GeryKnee
5,179件の閲覧回数
21件の返信
メッセージ1/22
GeryKnee
Hello to everyone.
I come back to my previous "purge all unused AcDbRasterImageDef entities" Post.
Problem ::
 I atach an image for example "C:\Users\Gery\Desktop\ACAD\[Problem]\Purge Unused Raster Image Reference\MyRemovedJpgXRef.jpg"
 I save the drawing document.
 I Quit Autocad
 I Restart Autocad by opening the previous document
 I delete the imade reference. The document now does'n include the image xref object.
 I Quit Autocad
 I export document as DXF format text
 I open the exported DXF
 Opening DXF using notepad
 I see those lines :::
AcDbDictionary
281
1
3
MyRemovedJpgXRef
350
264
0
AcDbRasterImageDef
90
0
1
10
253.0
20
165.0
11
 That is causing many problems with document. Those problems I described in my first post.
 Is there a solution to purge eny LIBRARY REFERENCE to a DELETED XREF REFERENCE as can be purged unsused BLOCK REFERNCED ?????
Gery
0 件のいいね
解決済み
5,180件の閲覧回数
21件の返信
返信 (21)
メッセージ2/22
Moshe-A
@GeryKnee ,
 I delete the image reference. The document now does'n include the image xref object.
why don't you purge it?
Moshe
0 件のいいね
メッセージ3/22
pendean
Community Legend
Community Legend
0 件のいいね
メッセージ4/22
GeryKnee
Because purge all doesn't purge it.
0 件のいいね
メッセージ5/22
Moshe-A
@GeryKnee ,
post a sample dwg
0 件のいいね
メッセージ6/22
Moshe-A
@GeryKnee ,
I think now got you and i read your previous thread also >> here <<
Raster images are similar to xrefs. when you attach an image, AutoCAD create a record in AcDbDictionary section for that image and than add an image reference to model space (or paper space if you are in layout). the same happens with xrefs. say you have a dwg file and you xattach it in - ok? AutoCAD create a record in the blocks table and than add a block reference in model space known as insert - are you agree?!
in order to remove an xref you must purge it.  the same goes with raster images. if you only delete them (by erase command) of course they are vanished form your drawing but they are still exist in AcDbDictionary section and the only way to remove it is purge.
so to summarize:-
if you want to remove a raster image, use purge directly (skipping erase) but if that image has multiple reference and you want to remove one (or some),  you would use erase.
does that make sense?
Moshe
0 件のいいね
メッセージ7/22
GeryKnee
I'm afraid, this is not solution.
I need a lisp code wich can purge all unused raster images, as happens for example to blocks (<<purge blocks>> removes blocks not referenced someware in a drawing).
my autocad platform is 2006 and purge doesn't work with images.
Newer versions of autocad maybe support this , but i'm too old to change the way i work.
Maybe lisp can do it.
Or maybe not.
Gery.
0 件のいいね
メッセージ8/22
Moshe-A
R2006 works on XP platform - Are you still working on XP/32 or win7/32?
post a sample dwg, please
0 件のいいね
メッセージ9/22
Moshe-A
@GeryKnee ,
check this PUIMG (Purge all Images) command. i test it on R2006 (i'm still keeping it in my Museum) and it works even dxfout it...and images are gone 😀
enjoy
Moshe
(defun c:puimg ()
 (vlax-for AcDbObject (vla-item
			(vla-get-dictionaries
			  (vla-get-activedocument (vlax-get-acad-object))
		       "ACAD_IMAGE_DICT")
  (vla-delete AcDbObject)
  (vlax-release-object AcDbObject)
 (princ)
メッセージ10/22
Moshe-A
here is a more complete  solution
purge-unreferenced-images
0 件のいいね
メッセージ11/22
GeryKnee
Yes,
That's solution.
Thank you very mach Moshe-A
Gery
0 件のいいね
メッセージ12/22
GeryKnee
dear Moshe-A
Now I see that this code deletes all images from the document.
So execudung the code, you loose any image assigned.
So it is non working as "purge all UNUSED IMAGES" but "Delete all images of the document"
My Op system is Windows 7
Gery
0 件のいいね
メッセージ13/22
GeryKnee
Hello Moshe-A
Would you please how suld i call this code from command Line??
Ger.
0 件のいいね
メッセージ14/22
trevor.bird.au
解決済み
Hi Gery,
Please try the following program:
;;  PurgeImages.lsp by Trevor Bird
;;  2021-02-20
(defun c:purgeimages
    ACAD_IMAGE_DICT__dxf
    ACAD_IMAGE_DICT__ename
    ACAD_REACTORS__dxf
    assoc_330
    count_imagedef
    count_imageref
    count_purged
    dps_3
    dps_330
    entity_dxf
    entity_ename
    entity_type
    imagedef_dxf
    imagedef_ename
    ImageFile
    imageref_dxf
    imageref_ename
    list_ImageNames
  (setq count_purged  0)
  (cond
    (  (not (setq ACAD_IMAGE_DICT__dxf    (dictsearch (namedobjdict) "ACAD_IMAGE_DICT"))))
    (  (not (setq ACAD_IMAGE_DICT__ename  (cdr (assoc -1 ACAD_IMAGE_DICT__dxf)))))
      ;;  dps_3 = xrecord names = image names
    (  (not (setq dps_3  (vl-remove-if-not '(lambda ( _dp ) (= (car _dp) 3)) ACAD_IMAGE_DICT__dxf))))
      ;;  List of xrecord names = list of image Names
    (  (not (setq list_ImageNames  (mapcar 'cdr dps_3))))
    (list_ImageNames
      (foreach fe__ImageName list_ImageNames
        (setq imagedef_dxf    (dictsearch ACAD_IMAGE_DICT__ename fe__ImageName)
              imagedef_ename  (cdr (assoc -1 imagedef_dxf))
              ImageFile       (cdr (assoc 1 imagedef_dxf))
        );setq
        (cond
          (  (not (setq ACAD_REACTORS__dxf  (member  '(102 . "{ACAD_REACTORS") imagedef_dxf))))
          (  (not
                (setq ACAD_REACTORS__dxf  (reverse (member '(102 . "}") (reverse ACAD_REACTORS__dxf)))
                      dps_330             (vl-remove-if-not '(lambda ( _dp ) (= (car _dp) 330)) ACAD_REACTORS__dxf)
                );setq
            );not
          (dps_330
            (setq count_imagedef  0
                  count_imageref  0
            );setq
            (foreach fe__dp dps_330
              (setq entity_ename  (cdr fe__dp)
                    entity_dxf    (entget entity_ename)
                    entity_type   (cdr (assoc 0 entity_dxf))
              );setq
              (cond
                (  (not (= entity_type "IMAGEDEF_REACTOR")))
                (  (not (setq count_imagedef  (1+ count_imagedef))))
                  ;;  330 - Object ID for associated image object (image reference)
                (  (not (setq assoc_330  (assoc 330 entity_dxf))))
                (assoc_330
                  (setq imageref_ename  (cdr assoc_330)
                        imageref_dxf    (entget imageref_ename)
                  );setq
                  (cond
                    (  (not imageref_dxf)
                      ;;  Image reference was deleted.
                    );(not imageref_dxf)
                    (imageref_dxf
                      (setq count_imageref  (1+ count_imageref))
                    );imageref_dxf
                  );cond
                );assoc_330
              );cond
            );fe__dp
            (if (zerop count_imageref)
              (progn
                ;;  Delete image definition xrecord.
                (setq count_purged  (1+ count_purged))
                (entdel imagedef_ename)
                (dictremove ACAD_IMAGE_DICT__ename fe__ImageName)
                (princ "\nDeleting image ")
                (prin1 fe__ImageName)
                (princ ".")
              );progn
            );if
          );dps_330
        );cond`
      );fe__ImageName
    );list_ImageNames
  );cond
  (cond
    (  (not (zerop count_purged))
      (princ "\n")
      (prin1 count_purged)
      (if (> count_purged 1)
        (princ " images ")
        (princ " image ")
      );if
      (princ "deleted.")
    );(not (zerop count_purged))
    (  (zerop count_purged)
      (princ "\nNo unreferenced images found.")
    );(zerop count_purged)
  );cond
  (princ)
);c:purgeimages
(princ "\nPurgeImages loaded. Start command with PURGEIMAGES.")
(princ)
Trevor
メッセージ15/22
Moshe-A
@GeryKnee ,
here is your lifeline 😀 PUIMG command.
moment before you rush to test it, read this:
i'm not beside my R2006, so the real test is on you.
this command purge all images that has no reference in current drawing. in order to do that, it scans the drawing database which include all blocks and layouts and make a list of all used images to filter them out from the list of images that are exist in Image Dictionary Database. Xrefs (including dependent blocks) are skipped.
After long exploring AutoCAD images i realized that we can not 100% rely on AutoCAD database to return the image name + it's path (the 2 properties this program is rely on) so i put maximum effort to retrieve this data from two direction and if they fail,  some images maybe skipped 🤔 and not purged.
at finish PUIMG will notify you how many images were purged.
enjoy
Moshe
(defun c:puimg (/ get_dict_data^ get_images_name _isexist filter_used_images purge_images ; local functions
                  dict_data^ images_name^ aid^ obj->rel unused^)
 ; return list of images dictionary data
 (defun get_dict_data^ ()
  (vl-remove-if
   'not
    (mapcar
     '(lambda (curr / succ)
        (if (and
              (= (car curr) 3)
              (= (car (setq succ (cadr (member curr aid^)))) 350)
         (cons (strcase (cdr curr)) (strcase (cdr (assoc '1 (entget (cdr succ))))))
      ); lambda
      (setq aid^ (dictsearch (namedobjdict) "acad_image_dict"))
    ); mapcar
  ); vl-remove-if
 ); get_dict_data^
 ; return a list of attached images
 (defun get_images_name (/ get_prop _dxd ; local function
                           AcDbBlockTableRecord AcDbEntity bname path name elist img^)
  (defun get_prop (func / str)
   (if
     (not
       (vl-catch-all-error-p
         (setq str (vl-catch-all-apply func (list AcDbRasterImage)))
    str
  ); get_prop
  ; anonymous function
  (setq _dxd (lambda (e) (vl-some '(lambda (bit) (= (logand bit (cdr (assoc '70 e))) bit)) '(4 8 16 32 64))))
  ; scan blocks database
  (vlax-for AcDbBlockTableRecord (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
   (if (and (setq bname (vla-get-name AcDbBlockTableRecord))
            (/= (substr bname 1 2) "*D")	    	      ; skip dimension block
            (not (_dxd (entget (tblobjname "block" bname))))  ; skip xrefs and dependent blocks
    ; scan objects inside block
    (vlax-for AcDbEntity AcDbBlockTableRecord
     (if (and
           (eq (vla-get-objectName AcDbEntity) "AcDbRasterImage")
           (or
             (and
               (setq path (get_prop 'vla-get-imageFile))
               (setq name (get_prop 'vla-get-name))
             (and
               (setq elist (entget (vlax-vla-object->ename AcDbEntity)))
               (setq path (cdr (assoc '1 (entget (cdr (assoc '340 elist))))))
               (setq name (vl-filename-base path))
           ); or
         ); and
       (if (not (_isexist (setq item (cons (strcase name) (strcase path))) img^))
        (setq img^ (cons (cons item img^))
      ); if
      (vlax-release-object AcDbEntity)
    ); vlax-for
   ); if
   (vlax-release-object AcDbBlockTableRecord)
  ); vlax-for
  img^
 ); get_images_name
 ; anonymous function, return T if item is already in list
 (setq _isexist (lambda (i0 lst) (vl-some '(lambda (i1) (equal i0 i1)) lst)))
 ; return a list of unsed imgaes
 (defun filter_used_images ()
  (vl-remove-if
   'not
   (mapcar
    '(lambda (item0)
      (if (not (_isexist item0 images_name^))
       item0
      ); if
    ); lambda
    dict_data^
   ); mapcar
  ); vl-remove-if
 ); filter_used_images
 ; real purge is done here
 (defun purge_images (lst / ctr ent)
  (setq ctr 0)
  (foreach item lst
   (if (setq ent (dictremove (cdar aid^) (car item)))
    (progn
     (entdel ent)
     (setq ctr (1+ ctr))
    ); progn
   ); if
  ); foreach
  (prompt (strcat "\n" (itoa ctr) " image(s) purged."))
 ); purge_images
 ; here start c:puimg
 (cond
  ((not (setq dict_data^ (get_dict_data^)))
   ; image dictionary data is empty, noting to purge
   (prompt "\nNo image(s) found to purge.")
  ); case
  ((not (setq images_name^ (get_images_name)))
   ; No images found in drawing, purge image dictionary data
   (purge_images image_data^)
  ); case
  ( t
   (foreach obj obj->rel (vlax-release-object obj)) ; dispose memory
   (if (setq unused^ (filter_used_images))
    (purge_images unused^)
    ; all images is inuse, noting to purge
   ); if
  ); case
 ); cond
 (princ)
); c:puimg
メッセージ16/22
Moshe-A
解決済み
@GeryKnee
fixed a bug + fine tuning 😀
Moshe
メッセージ17/22
GeryKnee
Yes Moshe-A
That's perfect
After all that's exactly the solution
Thank you very match
Gery
0 件のいいね
メッセージ18/22
GeryKnee
The code works perfectly
Thank you very match,
Sinceres,
Gery
0 件のいいね
メッセージ19/22
Lott99
Would this be easily modified to work on images that are "Not Found" as well as "Unreferenced"?
0 件のいいね
メッセージ20/22
trevor.bird.au
Hi Lott99,
I've updated this program to delete image references and purge the image if the image file cannot be found.
;;  2021-02-24
    ACAD_REACTORS__dxf
    assoc_330
    count_imagedef
    count_imageref
    count_purged
    dps_3
    dps_330
    entity_dxf
    entity_ename
    entity_type
    imagedef_dxf
    imagedef_ename
    ImageFile
    ImageFile_fqn
    imageref_dxf
    imageref_ename
    list_ImageNames
    sv_dwgprefix
  (cond
    (list_ImageNames
      (setq sv_dwgprefix (getvar 'DWGPREFIX))
        );setq
        (cond
          ( (setq ImageFile_fqn (findfile ImageFile)))
          ( (setq ImageFile_fqn (findfile (strcat sv_dwgprefix ImageFile))))
        );cond
        (cond
          ( (not
                );setq
            );not
          (dps_330
                  count_imageref  0
            );setq
              );setq
              (cond
                (assoc_330
                  );setq
                  (cond
                    ( (not ImageFile_fqn)
                      ;;  Image references exist but image file cannot be found.
                    );(not ImageFile_fqn)
                    (imageref_dxf
                    );imageref_dxf
                  );cond
                );assoc_330
              );cond
            );fe__dp
              (progn
                (princ ".")
              );progn
            );if
          );dps_330
        );cond
      );fe__ImageName
    );list_ImageNames
  );cond
  (cond
      (princ "\n")
        (princ " images ")
        (princ " image ")
      );if
      (princ "deleted.")
  );cond
  (princ)
);c:purgeimages
(princ)
Trevor Bird
0 件のいいね
