Probems with done_dialog
svucic
svucic
Hi everyone,
i'having troubles with seting a variable when exiting a DCL.
(action_tile "ecs" " (done_dialog 1) (setq userclick nil)")
(action_tile "oki" "(saveVars) (done_dialog)(setq userclick T)")
Whatever I do useclick is always T.
Here is my code, simplified
(defun C:EditAtrBlk ()
  (setq var0 nil )
  (setq var1 nil )
  (setq var2 nil )
  (setq var3 nil )
  (setq var4 nil )
  (setq var5 nil )
  ;(setq var6 nil )
  (setq var7 nil )
  (setq var8 nil )
  (setq var9 nil )
  ;(setq var10 nil )
  ;(setq var11 nil )
  (setq var12 nil )
  (setq var13 nil )
  (setq var14 nil )
  ;(setq var15 nil )
  (setq var16 nil )
  (setq var17 nil )
  (setq var18 nil )
(defun saveVars()
  (setq var0 (atoi (get_tile "atr110")))
  (setq var1 (atoi (get_tile "atr111")))
  (setq var2 (atoi (get_tile "atr112")))
  (setq var3 (atoi (get_tile "atr113")))
  (setq var4(get_tile "atr114"))
  (setq var5 (atoi (get_tile "mylist1")))
  (setq var6 (get_tile "atr115"))
  (setq var7 (atoi (get_tile "mylist2")))
  (setq var8 (atoi (get_tile "mylist3")))
  (setq var9 (atoi (get_tile "mylist4")))
  ;(setq var10 (get_tile "atr116"))
  (setq var11 (get_tile "atr117"))
  (setq var12 (atof (get_tile "atr118")))
  (setq var13 (atoi (get_tile "mylist5")))
  (setq var14 (atoi (get_tile "mylist6")))
  (setq var15 (get_tile "atr119"))
  (setq var16 (atoi (get_tile "mylist7")))
  (setq var17 (atoi (get_tile "mylist8")))
  (setq var18 (get_tile "znkid"))
  (setq var190 (get_tile "atr120"))
  (setq var200 (get_tile "atr121"))
  (if (and (setq d (vl-filename-mktemp nil nil ".dcl")) (setq f (open d "w")))
    (progn (write-line
             (strcat
			   "insertatr: dialog {
			   label = \"Unesi Atribute\";
			   " ": boxed_column {
			   fixed_width = true;
			   alignment = centered;
			   edit_width = 100;
			   " ": edit_box {
			   key = znkid;
			   label = \"ID:\";
               edit_width = 35;
               initial_focus = true;
				" ": column {
			   " ": edit_box {
 			   key = \"atr121\";
               label = \"+\";
               edit_width = 5;
               value = \"000.00\";
			   : errtile {alignment = centered;}
			   " ": boxed_row {
			   label = \"\";
			   fixed_width = true;
			   " ": button {
			   label = \"Okay\";
			   key = \"oki\";
			   is_default = true;
			   height = 1.75;
			   width = 12;}
			   " ": button {
			   label = \"Exit\";
			   key = \"esc\";
			   is_cancel = true;
			   height = 1.75;
			   width = 12;}
             f
           (close f)
    (alert "Can't load the temporary file <!>")
  ;/////////////////// PT1 KATEGORIJA /////////////////////////////
	(setq codespath (findfile "params.ini"))
	(setq lstdescrpt nil)
	(setq pt1 (dos_getini "1" nil codespath))
	(setq pt1x (dos_getini "1" nil codespath))
	(repeat (setq in (length pt1))
		(setq a (car pt1))
		(setq b (cdr pt1))
		(setq elementpt1 (dos_getini "1" a codespath))
				(setq lstdescrpt (cons  elementpt1 lstdescrpt))
				(setq pt1 b)
		(setq myListdecrpt (reverse lstdescrpt))
;///////////////// ROAD EXTERNAL CODE ////////////////////
(setq codespath (findfile "codes.ini"))
  (setq roadlist (dos_getini "sr_road" nil codespath))
  (setq roadlist1 (dos_getini "sr_road" nil codespath))
  (setq MyListRoad roadlist)
  (if(not(setq dcl_id (load_dialog d)))
    (progn
      (alert "The DCL file could not be loaded.")
      (exit)
    (progn
      (if (not (new_dialog "insertatr" dcl_id))
        (progn
          (alert "The definition could not be found inside the DCL file")
          (exit)
        (progn
		;atrsta atrplus atrsta1
		  (set_tile "atrsta" "1")
		  (mode_tile "atrsta" 0)
		  (set_tile "atrsta1" "200.00")
		  (mode_tile "atrsta1" 0)
		  (setq varmecategory "100")
		  (set_tile "atr111" varmecategory)
		  (mode_tile "atr111" 1)
		  (setq varmesubcategory "100")
		  (set_tile "atr112" varmesubcategory)
		  (mode_tile "atr112" 1)
		  (setq varmeclass "100")
		  (set_tile "atr113" varmeclass)
		  (mode_tile "atr113" 1)
		  (cond
			((= blkvar "portal")
					(setq codename (nth codelstportalval portallist1))
					(set_tile "atr114" codename)
					(mode_tile "atr114" 1)
			((= blkvar "stub")
					(setq codename (nth codelstpillarval pillarlist1))
			((= blkvar "ResetkastiNosac")
					(setq codename (nth codelstgridval gridlist1))
			((= blkvar "ElektricniStub")
					(setq codename (nth codelstelectricalval electricallist1))
		  (setq idnosaca (dos_guidgen))
		  (setq idnosaca1 (substr (repeat 5 (setq idnosaca (vl-string-subst "" "-" idnosaca))) 1 14))
		  (setq varid (strcat "A" idnosaca1))
		  (if editvarvpt
		  (progn
		  (set_tile "znkid" editid)
		  (mode_tile "znkid" 1)
		  (progn
		  (set_tile "znkid" varid)
		  (set_tile "atr115" edtrespcontractor)
		  (mode_tile "atr115" 0)
		  (if (or (not var190) (= var190 "") (= var190 0) (= var190 nil))
		  (progn
			(setq stationcode "0")
		  (progn
			(setq stationcode  var190)
		  (set_tile "atr120" stationcode)
		  (mode_tile "atr120" 0)
		  (if (or (not var200) (= var200 "") (= var200 nil))
		  (progn
			(setq stationcode1 "000.00")
		  (progn
			(setq stationcode1  var200)
		  (set_tile "atr121" stationcode1)
		  (mode_tile "atr121" 0)
		 ;(if (or (not var11) (= var11 "") (= var11 "0") (= var11 nil) (= (type VAR11) 'INT) (= (type VAR11) 'REAL))
		 ;(progn
		;(setq externcode "eksterna sifra puta")
		 ;(progn
		;(setq externcode  var11)
		 ;(set_tile "atr117" externcode)
		 ;(mode_tile "atr117" 0)
		  (if (or(not var15) (= var15 "") (= var15 nil) (= (type VAR15) 'INT) (= (type VAR15) 'REAL))
		  (progn
			(setq defdoccode "broj rjesenja")
		  (progn
			(setq defdoccode var15)
		  (set_tile "atr119" defdoccode)
		  (mode_tile "atr119" 0)
		  (start_list "atr111" 3)
          (mapcar 'add_list mylistdecrpt)
          (end_list)
		  (start_list "atr112" 3)
          (mapcar 'add_list myListdecrpt1)
          (end_list)
		  (start_list "atr113" 3)
          (mapcar 'add_list myListdecrpt2)
          (end_list)
		  (start_list "mylist1" 3)
          (mapcar 'add_list myList1)
          (end_list)
		  (set_tile "mylist1" edtcontractor)
		  (start_list "mylist2" 3)
          (mapcar 'add_list myList2)
          (end_list)
		  (set_tile "mylist2" edtprincipal)
		  (start_list "mylist3" 3)
          (mapcar 'add_list myList3)
          (end_list)
		  (set_tile "mylist3" edtonload)
		  (start_list "mylist4" 3)
          (mapcar 'add_list myList4)
          (end_list)
		  (start_list "mylist5" 3)
          (mapcar 'add_list myList5)
          (end_list)
		  (start_list "mylist6" 3)
          (mapcar 'add_list myList6)
          (end_list)
		  (start_list "mylist7" 3)
          (mapcar 'add_list myList7)
          (end_list)
		  (start_list "mylist8" 3)
          (mapcar 'add_list myList8)
          (end_list)
		  (_parsini "codes.ini" "sr_road")
		  (start_list "atr117" 3)
          (mapcar 'add_list inilist200)
          (end_list)
		  (set_tile "error" "Zapis stacionaze u formatu 0 + 0.000")
          (action_tile "ecs" " (done_dialog) (setq userclick nil)")
          (setq ddiag(start_dialog))
          (unload_dialog dcl_id)
	(if (not userclick)
	(exit)
	(setq roadlstindx (atoi var11))
	(if (= roadlstindx 0)
		(progn
			(alert "Nije izabrana eksterna sifra puta!")
		(progn
			(setq roadexterncode (nth roadlstindx inilist100))
	(setq var1 (atoi (nth var1 pt1x )))
	(setq var2 (atoi (nth var2 pt2x )))
	(setq var3 (atoi (nth var3 pt3x )))
	(setq stationcode1 (rtos (atof var190) 2 0))
	(setq stationcode2 (rtos (atof var200) 2 2))
	(setq stationcode (strcat stationcode1 "+" stationcode2))
	);end of insertatrblk
svucic
I managed to solve it by adding the status to done_dialog. Like this:
          (action_tile "ecs" "(done_dialog 0) (setq userclick nil)")
          (action_tile "oki" "(saveVars) (done_dialog 1)")
	(if (= ddiag 0)
	(progn
	(princ)
	(progn
	(princ)
john.uhden
That's the correct way to do it.  Good job!
John F. Uhden
