Batch inserting blocks via the Forge API
Message 1 of 1
I am trying to use the Forge API to insert a collection of blocks into a border arranged into a grid.
In my research into this I discovered a script wrote by Kent1Cooper which appears to to what I'm looking for. I've copied and tested the script but I cannot get it to run on my local version of AutoCAD.
(defun C:BC (/ blkfolder space nextLL rowht rowL blkLL blkUR objwid objht)
  (vl-load-com)
  (setvar 'osmode 0)
  (setq
    blkfolder (getfiled "Find folder" "Double-click any file in desired folder: " "dwg" 0)
    blkfolder (substr blkfolder 1 (1+ (vl-string-position 92 blkfolder 1 T))); path without dwg name
    space 1 ; between blocks and min. from limits <------ set as desired
    nextLL (mapcar '+ (getvar 'limmin) (list space space 0)); lower left of next block
    rowht 0 ; height of tallest block in row
    rowL nextLL; left end of baseline of row
  ); end setq
  (foreach blk (vl-directory-files blkfolder "*.dwg" 1)
    (command "_.insert" (strcat blkfolder blk) (getvar 'viewctr) "" "" "")
    (vla-getboundingbox (vlax-ename->vla-object (entlast)) 'minpt 'maxpt)
    (setq
      blkLL (vlax-safearray->list minpt)
      blkUR (vlax-safearray->list maxpt)
      objwid (- (car blkUR) (car blkLL))
      objht (- (cadr blkUR) (cadr blkLL))
    (if (> (+ (car nextLL) objwid space) (car (getvar 'limmax)))
      (setq ; then - start new row above previous row
        nextLL (polar rowL (/ pi 2) (+ rowht space))
        rowL nextLL
        rowht 0
      ); end setq
    ); end if - no else [next in current row]
    (command "_.move" (entlast) "" blkLL nextLL)
    (setq nextLL (polar nextLL 0 (+ objwid space)))
    (if (> objht rowht) (setq rowht objht))
  ); end foreach
); end defun
Could anybody help me understand why the script won't run or what I'd have to do to update it. I'm afraid it's a bit beyond my scripting skills.
Replies (0)
