Choose the line around the article
Hello there
When I select more than one font, how can I select the polyline that is enclosed in each of the surrounding areas?
Do not look up for English. Google translate
dbroad
Is there some reason that the rectangles and numbers are not part of a block?  The numbers could be attributes. Is there some variation in design of the rectangles?
Architect, Registered NC, VA, SC, & GA.
when i select the text, it automatically select the polyline enclosed by
hgasty1001
This may help to start, need more error checking:
(vl-load-com)
(defun c:GetEnclosingPoly(/ txt dxf ptxt pl px ss)
  (setq txt (car(entsel"\Select Text:")))
  (setq dxf (entget txt))
  (if (=(cdr (assoc 0 dxf)) "TEXT")
    (progn
      (setq ptxt (cdr (assoc 10 dxf)))
      (command "-boundary" ptxt "")
      (setq pl (entlast))
      (setq px (vlax-curve-getClosestPointTo pl ptxt))
      (entdel (entlast))
      (setq ss (ssget px '((0 . "LWPOLYLINE"))))
      (sssetfirst nil ss)
(princ)
Gaston Nunez
hi
thanx Gaston
can i use this with multiple selection
hgasty1001
Please explain what you mean with "multiple selection". If i understood correctly, you are talking about selecting multiple enclosed text objects, but i'm not sure, so please explain the use case.
Gaston Nunez
Yes you are right
Could you help
