Insert block to polyline
C.Utzinger
C.Utzinger
Hi
I have this code
(defun c:<Verteillinie ( / en start ang1 ang2 ende)
           (setvar "plinetype" 2)
	   (princ "\nStartpunkt angeben: ")
	   (command "_pline" (while (/=(getvar "CMDACTIVE")0)(command pause (princ "\nNächsten Punkt angeben (am Ende Enter): "))))
  (if (and (setq en (entlast))
           (wcmatch (cdr (assoc 0 (entget en))) "LWPOLYLINE,LINE,ARC")
           (setq start (vlax-curve-getStartPoint en))
           (setq ang1 (angle (trans '(0 0 0) 0 1) (trans (vlax-curve-getFirstDeriv en (vlax-curve-getStartParam en)) 0 1)))
           (setq start (trans start 0 1))
           (setq ende (vlax-curve-getEndPoint en))
           (setq ende (trans ende 0 1))
           (setq ang2 (angle (trans (vlax-curve-getFirstDeriv en (vlax-curve-getEndParam en)) 0 1)(trans '(0 0 0) 0 1)))
	   (command "_.insert" "spi-bew-pfeil" "_scale" 12.5 "_r" (angtos ang1) "_none" start
             "_.insert" "spi-bew-pfeil" "_scale" 12.5 "_r" (angtos ang2) "_none" ende))
           (prin1)
) ; end of defun
It works fine. But the arrows are not perfectly allined with the polyline.
Is something wrong in the code?
ВeekeeCZ
See the fixed code.
* The issue with precision was because (angtos) without any argument - it took a precision set in your drawing (_units command) which was not enough.
* The second issue was in the part where you drawing a polyline. That was messed up, it made each vertex twice!
Spoiler
  (command "_.pline")
  (while (> (getvar "CMDACTIVE") 0)
    (command pause)
    (command "_.insert" "spi-bew-pfeil" "_scale" 12.5 "_r" (angtos ang1 (getvar 'aunits) 10) "_none" start
	     "_.insert" "spi-bew-pfeil" "_scale" 12.5 "_r" (angtos ang2 (getvar 'aunits) 10) "_none" ende))
  (prin1)
  ) ; end of defun
C.Utzinger
Thank you!
Ranjit_Singh
try replacing (angtos ang1) and (angtos ang2) to (angtos ang1 0 14) and (angtos ang2 0 14)
