- Mute
- Permalink
- Report
Hi everyone,
i'having troubles with seting a variable when exiting a DCL.
(action_tile "ecs" " (done_dialog 1) (setq userclick nil)")
(action_tile "oki" "(saveVars) (done_dialog)(setq userclick T)")
Whatever I do useclick is always T.
Here is my code, simplified
(defun C:EditAtrBlk () (setq var0 nil ) (setq var1 nil ) (setq var2 nil ) (setq var3 nil ) (setq var4 nil ) (setq var5 nil ) ;(setq var6 nil ) (setq var7 nil ) (setq var8 nil ) (setq var9 nil ) ;(setq var10 nil ) ;(setq var11 nil ) (setq var12 nil ) (setq var13 nil ) (setq var14 nil ) ;(setq var15 nil ) (setq var16 nil ) (setq var17 nil ) (setq var18 nil ) (defun saveVars() (setq var0 (atoi (get_tile "atr110"))) (setq var1 (atoi (get_tile "atr111"))) (setq var2 (atoi (get_tile "atr112"))) (setq var3 (atoi (get_tile "atr113"))) (setq var4(get_tile "atr114")) (setq var5 (atoi (get_tile "mylist1"))) (setq var6 (get_tile "atr115")) (setq var7 (atoi (get_tile "mylist2"))) (setq var8 (atoi (get_tile "mylist3"))) (setq var9 (atoi (get_tile "mylist4"))) ;(setq var10 (get_tile "atr116")) (setq var11 (get_tile "atr117")) (setq var12 (atof (get_tile "atr118"))) (setq var13 (atoi (get_tile "mylist5"))) (setq var14 (atoi (get_tile "mylist6"))) (setq var15 (get_tile "atr119")) (setq var16 (atoi (get_tile "mylist7"))) (setq var17 (atoi (get_tile "mylist8"))) (setq var18 (get_tile "znkid")) (setq var190 (get_tile "atr120")) (setq var200 (get_tile "atr121")) ) (if (and (setq d (vl-filename-mktemp nil nil ".dcl")) (setq f (open d "w"))) (progn (write-line (strcat "insertatr: dialog { label = \"Unesi Atribute\"; " ": boxed_column { fixed_width = true; alignment = centered; edit_width = 100; " ": edit_box { key = znkid; label = \"ID:\"; edit_width = 35; initial_focus = true; } * * * * * * * * " ": column { " ": edit_box { key = \"atr121\"; label = \"+\"; edit_width = 5; value = \"000.00\"; initial_focus = true; } } } : errtile {alignment = centered;} " ": boxed_row { label = \"\"; fixed_width = true; alignment = centered; " ": button { label = \"Okay\"; key = \"oki\"; is_default = true; height = 1.75; width = 12;} " ": button { label = \"Exit\"; key = \"esc\"; is_cancel = true; height = 1.75; width = 12;} }}" ) f ) (close f) ) (alert "Can't load the temporary file <!>") ) ;/////////////////// PT1 KATEGORIJA ///////////////////////////// (setq codespath (findfile "params.ini")) (setq lstdescrpt nil) (setq pt1 (dos_getini "1" nil codespath)) (setq pt1x (dos_getini "1" nil codespath)) (repeat (setq in (length pt1)) (setq a (car pt1)) (setq b (cdr pt1)) (setq elementpt1 (dos_getini "1" a codespath)) (setq lstdescrpt (cons elementpt1 lstdescrpt)) (setq pt1 b) ) (setq myListdecrpt (reverse lstdescrpt)) ;------------------------------------------------------------ * * * * * * * ;///////////////// ROAD EXTERNAL CODE //////////////////// (setq codespath (findfile "codes.ini")) (setq roadlist (dos_getini "sr_road" nil codespath)) (setq roadlist1 (dos_getini "sr_road" nil codespath)) (setq MyListRoad roadlist) ;------------------------------------------------------------ (if(not(setq dcl_id (load_dialog d))) (progn (alert "The DCL file could not be loaded.") (exit) ) (progn (if (not (new_dialog "insertatr" dcl_id)) (progn (alert "The definition could not be found inside the DCL file") (exit) ) (progn ;atrsta atrplus atrsta1 (set_tile "atrsta" "1") (mode_tile "atrsta" 0) (set_tile "atrsta1" "200.00") (mode_tile "atrsta1" 0) (setq varmecategory "100") (set_tile "atr111" varmecategory) (mode_tile "atr111" 1) (setq varmesubcategory "100") (set_tile "atr112" varmesubcategory) (mode_tile "atr112" 1) (setq varmeclass "100") (set_tile "atr113" varmeclass) (mode_tile "atr113" 1) (cond ((= blkvar "portal") (setq codename (nth codelstportalval portallist1)) (set_tile "atr114" codename) (mode_tile "atr114" 1) ) ((= blkvar "stub") (setq codename (nth codelstpillarval pillarlist1)) (set_tile "atr114" codename) (mode_tile "atr114" 1) ) ((= blkvar "ResetkastiNosac") (setq codename (nth codelstgridval gridlist1)) (set_tile "atr114" codename) (mode_tile "atr114" 1) ) ((= blkvar "ElektricniStub") (setq codename (nth codelstelectricalval electricallist1)) (set_tile "atr114" codename) (mode_tile "atr114" 1) ) ) (setq idnosaca (dos_guidgen)) (setq idnosaca1 (substr (repeat 5 (setq idnosaca (vl-string-subst "" "-" idnosaca))) 1 14)) (setq varid (strcat "A" idnosaca1)) (if editvarvpt (progn (set_tile "znkid" editid) (mode_tile "znkid" 1) ) (progn (set_tile "znkid" varid) (mode_tile "znkid" 1) ) ) (set_tile "atr115" edtrespcontractor) (mode_tile "atr115" 0) (if (or (not var190) (= var190 "") (= var190 0) (= var190 nil)) (progn (setq stationcode "0") ) (progn (setq stationcode var190) )) (set_tile "atr120" stationcode) (mode_tile "atr120" 0) (if (or (not var200) (= var200 "") (= var200 nil)) (progn (setq stationcode1 "000.00") ) (progn (setq stationcode1 var200) )) (set_tile "atr121" stationcode1) (mode_tile "atr121" 0) ;(if (or (not var11) (= var11 "") (= var11 "0") (= var11 nil) (= (type VAR11) 'INT) (= (type VAR11) 'REAL)) ;(progn ;(setq externcode "eksterna sifra puta") ;) ;(progn ;(setq externcode var11) ;)) ;(set_tile "atr117" externcode) ;(mode_tile "atr117" 0) (if (or(not var15) (= var15 "") (= var15 nil) (= (type VAR15) 'INT) (= (type VAR15) 'REAL)) (progn (setq defdoccode "broj rjesenja") ) (progn (setq defdoccode var15) )) (set_tile "atr119" defdoccode) (mode_tile "atr119" 0) (start_list "atr111" 3) (mapcar 'add_list mylistdecrpt) (end_list) (start_list "atr112" 3) (mapcar 'add_list myListdecrpt1) (end_list) (start_list "atr113" 3) (mapcar 'add_list myListdecrpt2) (end_list) (start_list "mylist1" 3) (mapcar 'add_list myList1) (end_list) (set_tile "mylist1" edtcontractor) (start_list "mylist2" 3) (mapcar 'add_list myList2) (end_list) (set_tile "mylist2" edtprincipal) (start_list "mylist3" 3) (mapcar 'add_list myList3) (end_list) (set_tile "mylist3" edtonload) (start_list "mylist4" 3) (mapcar 'add_list myList4) (end_list) (start_list "mylist5" 3) (mapcar 'add_list myList5) (end_list) (start_list "mylist6" 3) (mapcar 'add_list myList6) (end_list) (start_list "mylist7" 3) (mapcar 'add_list myList7) (end_list) (start_list "mylist8" 3) (mapcar 'add_list myList8) (end_list) (_parsini "codes.ini" "sr_road") (start_list "atr117" 3) (mapcar 'add_list inilist200) (end_list) (set_tile "error" "Zapis stacionaze u formatu 0 + 0.000") (action_tile "ecs" " (done_dialog) (setq userclick nil)") (action_tile "oki" "(saveVars) (done_dialog)(setq userclick T)") (setq ddiag(start_dialog)) (unload_dialog dcl_id) ) ) ) ) (if (not userclick) (exit) ) (setq roadlstindx (atoi var11)) (if (= roadlstindx 0) (progn (alert "Nije izabrana eksterna sifra puta!") ) (progn (setq roadexterncode (nth roadlstindx inilist100)) ) ) * * * * * * * * (setq var1 (atoi (nth var1 pt1x ))) (setq var2 (atoi (nth var2 pt2x ))) (setq var3 (atoi (nth var3 pt3x ))) (setq stationcode1 (rtos (atof var190) 2 0)) (setq stationcode2 (rtos (atof var200) 2 2)) (setq stationcode (strcat stationcode1 "+" stationcode2)) );end of insertatrblk
