print pdf location to dwg folder map
larsr2866
Message 1 of 11
larsr2866
I have been using a lisp to automatically print to pdf with always the same pdf name (details.pdf). Only problem is that this doen't save it on the dwg folder map. Can someone help me with this?
(defun C:PPP (/)
(command "_.-PLOT" ;
"_yes" ;
"map02";
"Dwg To PDF.pc3" ;
"ISO full bleed A4 (210.00 x 297.00 MM)" ;
"_millimeters" ;
"_portrait"
"_no"
"_layout"
"1:1"
"0.00,0.00"
"_yes"
"mapcolor.ctb"
"_yes"
"_no"
"_no"
"_no"
"details"
"_no"
"_yes"
);_command
(princ) ;
Replies (10)
Message 2 of 11
dmfrazier
"...this doen't save it on the dwg folder map."
What does this mean?
Message 3 of 11
larsr2866
It creates the pdf with the correct name 'details.pdf', but i would like to automatically save this pdf in the folder of the dwg.
I hope someone could help me with this?
Thanks in advanve.
Message 4 of 11
dmfrazier
(setq fpath (getvar "DWGPREFIX")); set path based on current dwg
Message 5 of 11
larsr2866
It doesn't work when i use this. Am i doing something wrong?
Thanks in advance.
(defun C:PPP (/)
"_yes" ;
"map02";
"Dwg To PDF.pc3" ;
"_millimeters" ;
"_portrait"
"_no"
"_layout"
"1:1"
"0.00,0.00"
"_yes"
"mapcolor.ctb"
"_yes"
"_no"
"_no"
"_no"
"details"
"_no"
"_yes"
);_command
(princ) ;
Message 6 of 11
Moshe-A
@larsr2866  hi,
take a look at this >> PLOTTOFILEPATH <<  sysvar
Moshe
Message 7 of 11
dmfrazier
It's not enough just to set the variable. You have to use the variable in the name that you want the PDF file to have.
Replace the line that reads "details" with this:
(strcat fpath "details"); this concatenates the path and filename
Message 8 of 11
Moshe-A
that's right, this is only for the current session, as soon as you close\reopen AutoCAD this sysvar is reset.
Message 9 of 11
dmfrazier
My response was to the OP.
In the LISP he wrote, all he needs to do is modify it as I have shown. It will work no matter what drawing is open.
Message 10 of 11
larsr2866
Thanks to both! This worked perfect! 🙂
Message 11 of 11
Sea-Haven
Here is something that makes a PDF directory under the location of the dwg. So you use it with strcat your pdf name in the plot code..
; check that pdf directory exists
(setq dwgpre (strcat (getvar "dwgprefix") "\pdf"))
(if (= (vl-file-directory-p dwgpre) nil)
(vl-mkdir dwgpre)
