GET BLOCK ATTRIBUTE VALUE
atawk
atawk
I need a Lisp routine that allows to get the block attribute values into a multileader. I need to get the TAG value and PROMPT value into 2 different lines. (see attached picture).
dmfrazier
Assuming the attribute values are coming from the object (assuming it's an attributed block) that the mleader points to, can you simply add fields in the mleader text that reference the attributes in the block?
atawk
yes the attribute values will come from the selected block that include attribute. then the multileader will include these attribute values.
dmfrazier
Can you simply add fields in the mleader text that reference the attributes in the block?
paullimapa
Here are multiple threads online that will give you the tag and prompt values on the screen. It’s just a matter of modifying the code to feed this into mleader command
https://www.cadtutor.net/forum/topic/70636-get-tag-prompt-value-of-block-attributes/
https://www.theswamp.org/index.php?topic=36833.0
Paul Li
IT Specialist
@The Office
komondormrex
for all attribute definitions in block
(setq tag_prompt_list nil)
(setq insert (vlax-ename->vla-object (car (entsel "\nPick block reference: "))))
(vlax-map-collection (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (vla-get-effectivename insert))
	'(lambda (attribute_definition)
	 	(cond
			 	(= "AcDbAttributeDefinition" (vla-get-objectname attribute_definition))
			 		(setq tag_prompt_list (append tag_prompt_list (list (list (vla-get-tagstring attribute_definition)
												      	    (vla-get-promptstring attribute_definition)
			 	t
(setq mleader_text (apply 'strcat (mapcar '(lambda (_list) (apply 'strcat _list))
						    	(mapcar '(lambda (list_element) (strcat list_element "\\P"))
								_list
						    tag_prompt_list
(command "_mleader" "_h" (getpoint "\nPick mleader landing point: ") pause mleader_text "")
