Prevent mirror text in block inside block (Dynamic block with visibility parameter )
S_S_SS
S_S_SS
I Use dynamic block and visibility parameter
i insert more blocks in the final block
these blocks have names _i make it attribute and it is't constant attribute _ and when i select the final block and make it mirror the text mirror with block .....
i know that when i explode final block text will be normal ,but i need it dynamic to easily change it when i need
and i know that i can mirror final block about its center but it will be difficult when i have more of it
can someone help me about that ??
and thanks in advance.
pbejse
@S_S_SS wrote:
..these blocks have names _i make it attribute and it is't constant attribute _ and when i select the final block and make it mirror the text mirror with block .....
I am not understanding what you want @S_S_SS , do you want attributes?  and do you want it mirrored or not?
S_S_SS
No it's my problem that names of blocks mirror with block and i do't want that
pbejse
You tried constant attribute and it still flips when the block is mirrored correct?
I modified the  dynamic block.dwg at post #1 to regular attribute and place the ATTDEF in a locked layer
I only did it for 2 visibility names, see if that works for you
  • 4.50 M
  • 4.0 M
HTH
S_S_SS
thanks sir very much 😃
