LISP CHANGING HATCHING PROPERTIES
rahmathide_legion
rahmathide_legion
This Code is got an error
(defun C:H5 (\ D)
   (setq D (SSGET))
   (command "-HATCHEDIT"D"" "ansi32" "300" "0" "" )
   (princ)
this error is "unknown H5 command"
and my question is how to change with layer properties and hatch pattern of this code?
i'm new to work with lisp😄
hosneyalaa
( defun c : test (  / ss i en )
(  if   ( setq ss ( ssget ' (  (  0   .   "HATCH"  )   )  )  )
( progname
  ( repeater ( setq i ( sslength ss )  )
( setq en ( ssname ss ( setq i (  1  - i )  )  )  )
( setq objvl ( vlax - ename -  > vla -  object en )  )
( vla - setPattern objvl acHatchPatternTypePreDefined "ansi32"   )
( vlax - put - property objvl ' layer "0"  )
)  ; repeat
)  ;   if
( princ )
ВeekeeCZ
Here's your code fixed. For more info look HERE , HERE .
Some commands behaves a bit differently when used from autocad command-line or from LISP. The -hatchedit is the case. While in autocad you can select multiple objects, in lisp just single one. The (initcommandvesion) can help, usually, to get the current autocad version. BTW a good trick how to see the lisp-version behaviour is run (command-s "-hatchedit") from the command-line.
(defun c:H5 ( / d)  							; its the other one
  (if (setq d (ssget "_:L" '((0 . "HATCH"))))  				; limit the selection for HATCHes only, exclude objects in locked layers
    (progn
      (initcommandversion)						; lisp version of -hatchedit allows single selection only. this way you'll get autocad's version
      (command "-HATCHEDIT" d "" "_Properties"  "ansi32" 300 0)))
  (princ)
