Power Line Cable Sag
goswami5chirag
Message 1 of 41
goswami5chirag
Does anyone know about any function that can draw profile sag of Power Line Cable sag (Catenary) ?
Here is Picture for your reference for the kind of thing i wanted
Replies (40)
Message 41 of 41
_gile
@loitientran
The following code should work in 3D.
;; Draws a spline figuring a  3d catenary curve
;; Arguments
;; pt1 : start point
;; pt2 : end point
;; H   : horizontal tension
;; w   : unit weight
;; k   : vertical exaggeration (Y scale / X scale)
;; n   : number of fit points
(defun draw3dCatenary (pt1 pt2 H w k n / cosh sinh asinh fitPoints)
  ;; Returns the hyperbolic cosine
  (defun cosh (x)
    (/ (+ (exp x) (exp (- x))) 2.)
  ;; Returns the hyperbolic sine
  (defun sinh (x)
    (/ (- (exp x) (exp (- x))) 2.)
  ;; Returns the inverse hyperbolic sine
  (defun asinh (x)
    (log (+ x (sqrt (+ (* x x) 1.))))
  ;; Computes the n fit points of the spline figuring the catenary between pt1 and pt2
  ;; with a = H / w
  (defun fitPoints (pt1 pt2 n a k / norm p1 p2 x y z lg ht stp alpha beta gamma d1 d2 pts)
    (setq norm  (list (- (cadr pt1) (cadr pt2)) (- (car pt2) (car pt1)) 0.)
	  p1    (trans pt1 0 norm)
	  p2    (trans pt2 0 norm)
          x	(car p1)
	  y     (cadr p1)
	  z     (caddr p1)
	  lg	(- (car p2) x)
	  ht	(/ (- y (cadr p2)) k)
	  stp	(/ lg (- n 1))
	  alpha	(/ ht (* 2. a (sinh (/ lg (* 2. a)))))
	  beta	(+ (/ lg 2.) (* a (asinh alpha)))
	  gamma	(* a (- (cosh (/ beta a)) 1.))
	  d1	(+ x beta)
	  d2	(- y (* k gamma))
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
		  (trans
		    (list (setq x (+ x stp))
			  (+ (* k a (- (cosh (/ (- x d1) a)) 1.)) d2)
			  z
		    norm
		    0
		  pts
    (reverse (cons pt2 pts))
  (entmakex
    (append
      (list '(0 . "SPLINE")
	    '(100 . "AcDbEntity")
	    '(100 . "AcDbSpline")
	    (cons 70 8)
	    (cons 71 3)
	    (cons 74 (length lst-pts))
      (mapcar '(lambda (x) (cons 11 x))
	      (fitPoints pt1 pt2 n (/ H w) k)
;; Catenary settings dialog box
(defun catenarySettings (H w k n / temp file dcl_id status lst)
  (setq	temp (vl-filename-mktemp "Tmp.dcl")
	file (open temp "w")
  (write-line
    "Catenary: dialog {
      label = \"Catenary Settings\";
      : edit_box {
        key = \"tension\";
        edit_width=12;
        label = \"Horizontal Tension: \";
        allow_accept = true;
      : edit_box {
        key = \"weight\";
        edit_width=12;
        label = \"Unit Weight: \";
      : edit_box {
        key = \"exaggeration\";
        edit_width=12;
        label = \"Vertical Exaggeration: \";
      : edit_box {
        key = \"points\";
        edit_width=12;
        label = \"Number of Fit Points: \";
      spacer;
      ok_cancel;
    file
  (close file)
  (setq dcl_id (load_dialog temp))
  (if (not (new_dialog "Catenary" dcl_id))
    (exit)
  (set_tile "tension" (rtos H))
  (set_tile "weight" (rtos w))
  (set_tile "exaggeration" (rtos k))
  (set_tile "points" (itoa n))
  (action_tile
    "accept"
    (vl-prin1-to-string
      (quote
	(if (<= (distof (get_tile "tension")) 0.)
	  (progn
	    (alert "Needs a strictly positive real number.")
	    (mode_tile "tension" 2)
	  (if (<= (distof (get_tile "weight")) 0.)
	    (progn
	      (mode_tile "weight" 2)
	    (if	(<= (distof (get_tile "exaggeration")) 0.)
	      (progn
		(mode_tile "exaggeration" 2)
	      (if (<= (atoi (get_tile "points")) 6)
		(progn
		  (alert "Needs an integer greater than or equal to 7.")
		  (mode_tile "points" 2)
		(progn
		  (setq	lst (list
		  (done_dialog)
  (setq status (start_dialog))
  (unload_dialog dcl_id)
  (vl-file-delete temp)
  lst
;; Command
(defun c:3DCATENARY (/ pt1 pt2 H w k n)
  (mapcar '(lambda (sym key val)
	     (set sym
		  (cond
		    ((vlax-ldata-get "catenary" key))
		    ((vlax-ldata-put "catenary" key val))
	  '(H w k n)
	  '("tension" "weight" "exaggeration" "numPts")
	  '(3000.0 2.0 1.0 17)
  (while
    (not
      (or
	(initget "Settings")
	(vl-consp (setq	pt1
			 (getpoint
			   (strcat
			     "\nCurrent settings: Horizontal Tension = "
			     (rtos H)
			     " - Unit Weight = "
			     (rtos w)
			     " - Vertical Exaggeration = "
			     (rtos k)
			     " - Number of Fit Points = "
			     (itoa n)
			     "\nStart point or [Settings] <S>: "
     (if (setq lst (catenarySettings H w k n))
		  (set sym (vlax-ldata-put "catenary" key val))
	       '(H w k n)
	       lst
  (while
    (setq pt2 (getpoint pt1 "\nNext point (or Enter to quit): "))
     (draw3dCatenary (trans pt1 1 0) (trans (setq pt1 pt2) 1 0) H w k n)
  (princ)
Gilles Chanteau
GileCAD
GitHub
