Power Line Cable Sag
goswami5chirag
Message 1 of 41
goswami5chirag
Does anyone know about any function that can draw profile sag of Power Line Cable sag (Catenary) ?
Here is Picture for your reference for the kind of thing i wanted
Replies (40)
Message 21 of 41
goswami5chirag
Asking for littile more help,
on the same programme i want to add line in the Lowest point of the curve..
here is a photo for reference.
Message 22 of 41
Sea-Haven
I tried the code is there a typo ?
lst-pts should it be pts ? It works then.
Lowest pt as you now have pts list can find the pt with lowest Y, would probably redo the pts involved say 100 steps to get a more accurate X&Y. Keep the dwg as is only use the larger step size for the XY.
Message 23 of 41
goswami5chirag
Not understood , I want a line to show the Null point of the curve, that should be generated by the programme at the same time of creating the curve.
Message 24 of 41
Sea-Haven
I posted as a possible solution to Gile he is a very good programmer so I am sure if he can find time will add the request.
Message 25 of 41
goswami5chirag
Still did not get any solution..please help.!!
Message 26 of 41
marko_ribar
Look at this function :
(vlax-curve-getclosestpointtoprojection)
HTH. M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 27 of 41
goswami5chirag
Can't find any Function ?
Message 28 of 41
Sea-Haven
Hope Gile does not mind but added a low pt.
;; Draws a spline figuring a catenary
;; By Gile
;; Arguments
;; pt1 : start point
;; pt2 : end point
;; n   : number of fit points
;; th  : horizontal tension (N)
;; w   : unit weight (kg)
;; lowest point added by AlanH
(defun drawCatenary (pt1 pt2 n th w / cosh sinh asinh fitPoints)
  ;; Returns the hyperbolic cosine
  (defun cosh (x)
    (/ (+ (exp x) (exp (- x))) 2.)
  ;; Returns the hyperbolic sine
  (defun sinh (x)
    (/ (- (exp x) (exp (- x))) 2.)
  ;; Returns the inverse hyperbolic sine
  (defun asinh (x)
    (log (+ x (sqrt (+ (* x x) 1.))))
  ;; Computes the n fit points of the spline figuring the catenary between pt1 and pt2
  ;; with a = Th / (µ * 9.81)
(defun fitPoints (pt1 pt2 n a / lg ht stp alpha beta gamma d1 d2 x)
  (setq pts '())
    (setq x	(car pt1)
	  lg	(- (car pt2) x)
	  ht	(- (cadr pt1) (cadr pt2))
	  stp	(/ lg (- n 1))
	  alpha	(/ ht (* 2. a (sinh (/ lg (* 2. a)))))
	  beta	(+ (/ lg 2.) (* a (asinh alpha)))
	  gamma	(* a (- (cosh (/ beta a)) 1.))
	  d1	(+ x beta)
	  d2	(- (cadr pt1) gamma)
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
		  (list	(setq x (+ x stp))
			(+ (* a (- (cosh (/ (- x d1) a)) 1.)) d2)
			0.
		  pts
    (reverse (cons pt2 pts))
(defun c:CATENARY (/ pt1 pt2 th w n)
  (and
    (setq pt1 (getpoint "\nStart point: "))
    (setq pt2 (getpoint pt1 "\nEnd point: "))
    (setq th (getreal "\nHorizontal tension (Newtons): "))
    (setq w (getreal "\nUnit weight (Kilograms): "))
    (setq n 9) ;_ number of fit points
    (drawCatenary pt1 pt2 n th w)
    (entmakex
    (append
      (list '(0 . "SPLINE")
	    '(100 . "AcDbEntity")
	    '(100 . "AcDbSpline")
	    (cons 70 8)
	    (cons 71 3)
	    (cons 74 (length pts))
      (mapcar '(lambda (x) (cons 11 x))
	      (fitPoints pt1 pt2 n (/ th (* w 9.81)))
    (fitPoints pt1 pt2 100 (/ th (* w 9.81)))
    (setq pts (vl-sort pts '(lambda (x y) (< (cadr x)(cadr y)))))
    (command "point" (car pts))
    (setvar 'pdmode 34)
  (princ)
Message 29 of 41
goswami5chirag
Not working
Message 30 of 41
goswami5chirag
Its not working - "error: no function definition: FITPOINTS"
Message 31 of 41
Sea-Haven
Ok it works now but did some more testing.
Pain in the, can not edit a previous post all other forums let you update / remove code etc.
;; Draws a spline figuring a catenary by Gile
;; Arguments
;; pt2 : end point
;; Lowest point added by AlanH
  (defun cosh (x)
  (defun sinh (x)
  (defun asinh (x)
    (setq x	(car pt1)
	  lg	(- (car pt2) x)
	  stp	(/ lg (- n 1))
	  d1	(+ x beta)
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
			0.
		  pts
  (entmakex
    (append
	    (cons 70 8)
	    (cons 71 3)
  (setq pts nil)
  (setvar 'pdmode 34)
  (and
    (setq n 10) ;_ number of fit points
  (princ)
(c:CATENARY )
Message 32 of 41
goswami5chirag
Can you Update  this on the earlier Programme so that I can use this on a continous way. Also the curve dosent seem to Match , The accuracy of the curve is ok in the Earlier Programme .
Message 33 of 41
Sea-Haven
I used 100 steps to work out low pt, but the program used like 9 for the illustration so the point does not match, the points are spline fit rather than a series of say straights. I am a civil engineer and for years road Vertical curves have been plotted as a pline with little tiny straight segments.
In the updated code Gile asks for how many steps so could do 100 or change my code to a lower value depends on how accurate you want it. I can say at 9 steps for curve compared 100 for low pt,  there is a big difference but curve looks good.
You could change the POINT to say text writing X & Y value but would want something like,
Left pole xxxrl
low pt aaaarl
right pole bbbbrl
Your opportunity to have a go at coding.
Message 34 of 41
goswami5chirag
There is a huge difference in the curve is not matching with my templateScreenshot (41).png
Message 35 of 41
darkfuneral
The tension is clear to me, but the weight is it in KG for the span (lets say 50 m * 0.771 kg/km = 38.55 kg for the wire in the span) or is it in 'kg/km', 'kg/m'. If it's the weight in the span(50 m) and the next span is different (80 m), how to set it?
The other thing is the exaggeration 'k' is it the raito between X and Y? If I want X to be 1:500 scale and Y to be 1:2000 scale, so k=4 ?.
It works very well, I just need some clarifications 🙂
Thanks in advance,
Plamen
Message 36 of 41
Sea-Haven
The quick way to do this is to draw it at 1:1 then make it all a block then change the X & Y scales to suit, then explode.
Message 37 of 41
loitientran
Your code is great, however, if applied in a 3D CAD environment to draw a curve connecting two points of a hanging electrical wire, there will be issues with UCS (User Coordinate System) transformations. Could you upgrade it further?
Message 38 of 41
Sea-Haven
If you set a UCS plane through the 2 points then the code should work. You may need to just work with the 2 points having a dummy z of 0 for the plane to work correctly.
Message 39 of 41
loitientran
This method is to manually put 2 points into a plane. However, a power line project will have many pairs of points, so manual operation like this will take a lot of time. My wish is to automatically switch UCS when selecting any 2 points to draw a curve.
Message 40 of 41
Sea-Haven
"My wish is to automatically switch UCS when selecting any 2 points to draw a curve" That is what I was suggesting. get the 2 points as XYZ but convert the Z to zero. Use these 2 points as the starting point of a vertical UCS. You then need to re-arrange the XYZ of the points to suit the new UCS and run the lisp.
