Power Line Cable Sag
goswami5chirag
Message 1 of 41
goswami5chirag
Does anyone know about any function that can draw profile sag of Power Line Cable sag (Catenary) ?
Here is Picture for your reference for the kind of thing i wanted
Replies (40)
Message 2 of 41
_gile
What's wrong with the _CATENARY command from CustomCurves plugin?
Gilles Chanteau
GileCAD
GitHub
Message 3 of 41
goswami5chirag
I want a programme that can draw a catenary curve excatly to the parameter of a cable with particular unit weight and tension to it
Message 4 of 41
goswami5chirag
On which unit does that tension and Unit weight of conductor works
Message 5 of 41
goswami5chirag
I want tension in N, and unit weight in KG
Message 6 of 41
_gile
OK.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 41
_gile
You can try this:
;; Draws a spline figuring a catenary
;; Arguments
;; pt1 : start point
;; pt2 : end point
;; n   : number of fit points
;; th  : horizontal tension (N)
;; w   : unit weight (kg)
(defun drawCatenary (pt1 pt2 n th w / cosh sinh asinh fitPoints)
  ;; Returns the hyperbolic cosine
  (defun cosh (x)
    (/ (+ (exp x) (exp (- x))) 2.)
  ;; Returns the hyperbolic sine
  (defun sinh (x)
    (/ (- (exp x) (exp (- x))) 2.)
  ;; Returns the inverse hyperbolic sine
  (defun asinh (x)
    (log (+ x (sqrt (+ (* x x) 1.))))
  ;; Computes the n fit points of the spline figuring the catenary between pt1 and pt2
  ;; with a = Th / (µ * 9.81)
  (defun fitPoints (pt1 pt2 n a / lg ht stp alpha beta gamma d1 d2 x)
    (setq x	(car pt1)
	  lg	(- (car pt2) x)
	  ht	(- (cadr pt1) (cadr pt2))
	  stp	(/ lg (- n 1))
	  alpha	(/ ht (* 2. a (sinh (/ lg (* 2. a)))))
	  beta	(+ (/ lg 2.) (* a (asinh alpha)))
	  gamma	(* a (- (cosh (/ beta a)) 1.))
	  d1	(+ x beta)
	  d2	(- (cadr pt1) gamma)
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
		  (list	(setq x (+ x stp))
			(+ (* a (- (cosh (/ (- x d1) a)) 1.)) d2)
			0.
		  pts
    (reverse (cons pt2 pts))
  (entmakex
    (append
      (list '(0 . "SPLINE")
	    '(100 . "AcDbEntity")
	    '(100 . "AcDbSpline")
	    (cons 70 8)
	    (cons 71 3)
	    (cons 74 (length lst-pts))
      (mapcar '(lambda (x) (cons 11 x))
	      (fitPoints pt1 pt2 n (/ th (* w 9.81)))
(defun c:CATENARY (/ pt1 pt2 th w n)
  (and
    (setq pt1 (getpoint "\nStart point: "))
    (setq pt2 (getpoint pt1 "\nEnd point: "))
    (setq th (getreal "\nHorizontal tension (Newtons): "))
    (setq w (getreal "\nUnit weight (Kilograms): "))
    (setq n 9) ;_ number of fit points
    (drawCatenary pt1 pt2 n th w)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 8 of 41
goswami5chirag
Command for activating this ?
Message 9 of 41
goswami5chirag
it does not seems to  matching at my defult values, maybe the scale is different. i want function in 1:2000 horizontal scale and 1:200 vertical scale
Message 10 of 41
goswami5chirag
 what is the difference between Horizontal Tension and Tension of Conductor on particular Temperature ?
My default values are as follows :
Unit Weight of Conductor : 2.004 Kg/m
Tension: 3024 Kgs (At 85d , No wind )
Scale: Horizontal - 1:2000
            Vertical - 1:200
Message 11 of 41
goswami5chirag
The green one is my defult curve for
Unit Weight - 2.004 kg/m
Tension  - 3024 Kgs
Scale -  1:2000(Horizontal)
              1:200 (Vertical)
your function does not seem to match ( dont know the reason) .
Message 12 of 41
_gile
I'm sorry but it's very difficult for me to understand what you want.
You were talking about Tension in Newtons in  a previous reply, now you give: "Tension - 3024 Kgs".
The formula the LISP uses is based on Horizontal tension, are we talking about the same thing ?
In the upper picture, the dimensions are unreadable, so this it is useless.
Gilles Chanteau
GileCAD
GitHub
Message 13 of 41
goswami5chirag
Sorry for that,
The below mentioned data is my default data, and by using same data in your "Catenary" function the difference in result is shown in below Picture.Screenshot (31).png
Tension  - 3024 Kgs
              1:200 (Vertical)
For your reference the Red Curve is the actual Template i am having.
and the yellow line is the one i get after using "Catenary " Lisp that you provide
Message 14 of 41
_gile
Sorry, it's still not clear, the code I provided needs a value in Newtons for the horizontal tension.
And please attach a relevant sample drawing instead of pictures.
Gilles Chanteau
GileCAD
GitHub
Message 15 of 41
goswami5chirag
Here is a sample file for your reference, and template for matching the curve
Message 16 of 41
_gile
The following code should reply to your request.
The generated curve is slightly different from the template one because the template one seems to be a parabola instead of a catenary curve.
The user is prompted to specify the start and end points, the tension, the unit weight and the vertical exaggeration (Y scale / X scale). The previously entered values are purposed as default values (just click Enter to accept).
;; Arguments
;; pt2 : end point
;; w   : unit weight
;; k   : vertical exaggeration (Y scale / X scale)
(defun drawCatenary (pt1 pt2 n th w k / cosh sinh asinh fitPoints)
  (defun cosh (x)
  (defun sinh (x)
  (defun asinh (x)
  ;; with a = Th / w
  (defun fitPoints (pt1 pt2 n a k / lg ht stp alpha beta gamma d1 d2 x)
    (setq x	(car pt1)
	  lg	(- (car pt2) x)
	  ht	(/ (- (cadr pt1) (cadr pt2)) k)
	  stp	(/ lg (- n 1))
	  d1	(+ x beta)
	  d2	(- (cadr pt1) (* k gamma))
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
			(+ (* k a (- (cosh (/ (- x d1) a)) 1.)) d2)
			0.
		  pts
  (entmakex
    (append
	    (cons 70 8)
	    (cons 71 3)
	      (fitPoints pt1 pt2 n (/ th w) k)
;; default values
(setq *tension* 3024.)
(setq *unitWeight* 2.004)
(setq *exaggeration* 10.)
(setq *numFitPoints* 17)
;; Command CATENARY
(defun c:CATENARY (/ pt1 pt2 th w n k)
  (if
    (and
     (progn
       (if (setq th (getreal
		      (strcat
			"\nHorizontal tension <"
			(rtos *tension*)
	 (setq *tension* th)
	 (setq th *tension*)
       (if (setq w (getreal
		     (strcat
		       "\nUnit weight <"
		       (rtos *unitWeight*)
	 (setq *unitWeight* w)
	 (setq w *unitWeight*)
       (if (setq k (getreal
		     (strcat "\nVertical exaggeration <"
			     (rtos *exaggeration*)
	 (setq *exaggeration* k)
	 (setq k *exaggeration*)
       (drawCatenary (trans pt1 1 0) (trans pt2 1 0) *numFitPoints* th w k)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 17 of 41
goswami5chirag
The results were very good , just want one more thing to this function which is if i can do this with multiple points at the same time ,it would be really appreciated.
Message 18 of 41
_gile
;; Arguments
;; pt2 : end point
;; w   : unit weight
  (defun cosh (x)
  (defun sinh (x)
  (defun asinh (x)
  ;; with a = Th / w
    (setq x	(car pt1)
	  lg	(- (car pt2) x)
	  stp	(/ lg (- n 1))
	  d1	(+ x beta)
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
			0.
		  pts
  (entmakex
    (append
	    (cons 70 8)
	    (cons 71 3)
;; default values
;; Command CATENARY
		      (strcat
			(rtos *tension*)
	 (setq *tension* th)
	 (setq th *tension*)
		     (strcat
		       "\nUnit weight <"
		       (rtos *unitWeight*)
  (if (setq pt1 (getpoint "\nStart point: "))
    (while (setq pt2 (getpoint pt1 "\nNext point (or Enter to quit): "))
      (drawCatenary
	(trans pt1 1 0)
	(trans pt2 1 0)
	*numFitPoints*
	th
	w
	k
      (setq pt1 pt2)
  (princ)
Gilles Chanteau
GileCAD
GitHub
Message 19 of 41
goswami5chirag
this is exactly what i want, thank you so much ,really appreciated your work.
Message 20 of 41
_gile
With a more friendly user interface.
;; Draws a spline figuring a catenary curve
;; Arguments
;; pt2 : end point
;; H   : horizontal tension
;; w   : unit weight
(defun drawCatenary (pt1 pt2 H w k n / cosh sinh asinh fitPoints)
  (defun cosh (x)
  (defun sinh (x)
  (defun asinh (x)
  ;; with a = H / w
    (setq x	(car pt1)
	  lg	(- (car pt2) x)
	  stp	(/ lg (- n 1))
	  d1	(+ x beta)
	  pts	(list pt1)
    (repeat (- n 2)
      (setq pts	(cons
			0.
		  pts
  (entmakex
    (append
	    (cons 70 8)
	    (cons 71 3)
	      (fitPoints pt1 pt2 n (/ H w) k)
;; Catenary settings dialog box
(defun catenarySettings (H w k n / temp file dcl_id status lst)
  (setq	temp (vl-filename-mktemp "Tmp.dcl")
	file (open temp "w")
  (write-line
    "Catenary: dialog {
      label = \"Catenary Settings\";
      : edit_box {
        key = \"tension\";
        edit_width=12;
        label = \"Horizontal Tension: \";
        allow_accept = true;
      : edit_box {
        key = \"weight\";
        edit_width=12;
        label = \"Unit Weight: \";
      : edit_box {
        key = \"exaggeration\";
        edit_width=12;
        label = \"Vertical Exaggeration: \";
      : edit_box {
        key = \"points\";
        edit_width=12;
        label = \"Number of Fit Points: \";
      spacer;
      ok_cancel;
    file
  (close file)
  (setq dcl_id (load_dialog temp))
  (if (not (new_dialog "Catenary" dcl_id))
    (exit)
  (set_tile "tension" (rtos H))
  (set_tile "weight" (rtos w))
  (set_tile "exaggeration" (rtos k))
  (set_tile "points" (itoa n))
  (action_tile
    "accept"
    (vl-prin1-to-string
      (quote
	(if (<= (distof (get_tile "tension")) 0.)
	  (progn
	    (alert "Needs a strictly positive real number.")
	    (mode_tile "tension" 2)
	  (if (<= (distof (get_tile "weight")) 0.)
	    (progn
	      (mode_tile "weight" 2)
	    (if	(<= (distof (get_tile "exaggeration")) 0.)
	      (progn
		(mode_tile "exaggeration" 2)
	      (if (<= (atoi (get_tile "points")) 6)
		(progn
		  (alert "Needs an integer greater than or equal to 7.")
		  (mode_tile "points" 2)
		(progn
		  (setq	lst (list
		  (done_dialog)
  (setq status (start_dialog))
  (unload_dialog dcl_id)
  (vl-file-delete temp)
  lst
;; Command
(defun c:CATENARY (/ pt1 pt2 H w k n)
  (mapcar '(lambda (sym key val)
	     (set sym
		  (cond
		    ((vlax-ldata-get "catenary" key))
		    ((vlax-ldata-put "catenary" key val))
	  '(H w k n)
	  '("tension" "weight" "exaggeration" "numPts")
	  '(3000.0 2.0 1.0 17)
  (while
    (not
      (or
	(initget "Settings")
	(vl-consp (setq	pt1
			 (getpoint
			   (strcat
			     "\nCurrent settings: Horizontal Tension = "
			     (rtos H)
			     " - Unit Weight = "
			     (rtos w)
			     " - Vertical Exaggeration = "
			     (rtos k)
			     " - Number of Fit Points = "
			     (itoa n)
			     "\nStart point or [Settings] <S>: "
     (if (setq lst (catenarySettings H w k n))
		  (set sym (vlax-ldata-put "catenary" key val))
	       '(H w k n)
	       lst
  (while
     (drawCatenary (trans pt1 1 0) (trans (setq pt1 pt2) 1 0) H w k n)
  (princ)
Gilles Chanteau
GileCAD
GitHub
