- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Asking for a help from lisp Gurus :
Here is a file with blocks with attributes wich define the position, the quantity and lenght of the rebar ( polyline ); in this file is also the result for what I am asking for !!( a table wich represent each segment lenght of polyline { multiplied by 10} [in excell MROUND function ])
I am do it manually first step I am using this lisp :
(vl-load-com) (defun c:mult-info_po2CSV ( / js file_name cle f_open key_sep str_sep oldim lst_lay-seg lst_id-seg lst_pt lst_length lst_alpha lst_rad nb id n obj ename pr dist_start dist_end pt_start pt_end seg_len seg_bulge rad alpha) (princ "\nSelectionner les polylignes optimisees.") (while (null (setq js (ssget '((0 . "LWPOLYLINE"))))) (princ "\nSelection vide, ou ce ne sont pas des LWPOLYLINE!") ) (command "_.ddunits" (while (not (zerop (getvar "cmdactive"))) (command pause) ) ) (setq file_name (getfiled "Nom du fichier a creer ?: " (strcat (substr (getvar "dwgname") 1 (- (strlen (getvar "dwgname")) 3)) "csv") "csv" 37)) (if (null file_name) (exit)) (if (findfile file_name) (progn (prompt "\nFichier existe deja!") (initget "Ajoute Remplace annUler _Add Replace Undo") (setq cle (getkword "\nDonnees dans fichier? [Ajouter/Remplacer/annUler] <R>: ") ) (cond ((eq cle "Add") (setq cle "a") ) ((or (eq cle "Replace") (eq cle ())) (setq cle "w") ) (T (exit)) ) (setq f_open (open file_name cle)) ) (setq f_open (open file_name "w")) ) (initget "Espace Virgule Point-virgule Tabulation _SPace Comma SEmicolon Tabulation") (setq key_sep (getkword "\nSeparateur [Espace/Virgule/Point-virgule/Tabulation]? <Point-virgule>: ")) (cond ((eq key_sep "SPpace") (setq str_sep " ")) ((eq key_sep "Comma") (setq str_sep ",")) ((eq key_sep "Tabulation") (setq str_sep "\t")) (T (setq str_sep ";")) ) (setq oldim (getvar "dimzin")) (setvar "dimzin" 0) (setq lst_lay-seg '() lst_id-seg '() lst_pt '() lst_length '() lst_alpha '() lst_rad '() nb 0 id 0 ) (repeat (setq n (sslength js)) (setq obj (ssname js (setq n (1- n))) ename (vlax-ename->vla-object obj) pr -1 id (1+ id) nb 1 ) (repeat (fix (vlax-curve-getEndParam ename)) (setq dist_start (vlax-curve-GetDistAtParam ename (setq pr (1+ pr))) dist_end (vlax-curve-GetDistAtParam ename (1+ pr)) pt_start (vlax-curve-GetPointAtParam ename pr) pt_end (vlax-curve-GetPointAtParam ename (1+ pr)) seg_len (- dist_end dist_start) seg_bulge (vla-GetBulge ename pr) rad (if (zerop seg_bulge) 0.0 (/ seg_len (* 4.0 (atan seg_bulge)))) alpha (if (zerop seg_bulge) (angle pt_start pt_end) 0.0) lst_lay-seg (cons (cdr (assoc 8 (entget obj))) lst_lay-seg) lst_id-seg (cons (strcat "P" (itoa id) "-" (itoa nb)) lst_id-seg) lst_pt (cons pt_start lst_pt) lst_length (cons seg_len lst_length) lst_rad (cons (abs rad) lst_rad) lst_alpha (cons alpha lst_alpha) nb (1+ nb) ) ) (if (eq (vla-get-closed ename) :vlax-false) (setq lst_id-seg (cons (strcat "P" (itoa id) "-" (itoa nb)) lst_id-seg)) (setq lst_id-seg (cons (strcat "P" (itoa id) "-" (itoa (- nb (fix (vlax-curve-getEndParam ename))))) lst_id-seg)) ) (setq lst_pt (cons pt_end lst_pt) lst_lay-seg (cons (cdr (assoc 8 (entget obj))) lst_lay-seg) lst_length (cons 0.0 lst_length) lst_rad (cons 0.0 lst_rad) lst_alpha (cons 0.0 lst_alpha) nb (1+ nb) ) ) ;(write-line (strcat "Sommaire de " (itoa (sslength js)) " LWPOLYLINES") f_open) (foreach n (reverse (mapcar'list (append (mapcar '(lambda (x) (strcat x str_sep)) lst_lay-seg) (list (strcat "Calque" str_sep))) (append (mapcar '(lambda (x) (strcat x str_sep)) lst_id-seg) (list (strcat "N°" str_sep))) (append (mapcar '(lambda (x) (strcat (rtos x) str_sep)) (mapcar 'car lst_pt)) (list (strcat "Coordonnees X" str_sep))) (append (mapcar '(lambda (x) (strcat (rtos x) str_sep)) (mapcar 'cadr lst_pt)) (list (strcat "Coordonnees Y" str_sep))) (append (mapcar '(lambda (x) (strcat (rtos x) str_sep)) lst_length) (list (strcat "Longueurs" str_sep))) (append (mapcar '(lambda (x) (strcat (angtos x) str_sep)) lst_alpha) (list (strcat "Angles" str_sep))) (append (mapcar '(lambda (x) (strcat (rtos x) str_sep)) lst_rad) (list (strcat "Rayons" str_sep))) ) ) (write-line (apply 'strcat n) f_open) ) (close f_open) (setvar "dimzin" oldim) (prin1) )
then I have few formulas there , but it takes to much times
If it's not possible : I have another question :
is it possible in lisp that I attached to export also in excell the polyline
ObjId number (example 879607830404
Is it possible to create an attribute in my block witch also may reprezent this ObjId number , then for me it will be more easy to associate them in excell
I know it could be done quick, but only with your help!!!!!!!!
THANKS IN ADVANCE !!!!!!!!!
