How to GET a "Folder Name"...
hello everyone:
I need some help...
how to get  a folder name that is different depending of the REVIT VERSION.... (see underline folder name below)
(setq OldPath (getvar "dwgprefix"))                                              ;;;  I get             "U:\\100000\\elec\\"
(setq len (strlen OldPath))                                                             ;;;  I get               "15"
(setq FullPath2 (substr OldPath 1 (- len 1)))                                   ;;; I get                "U:\\100000\\mech"
(setq split_path (dos_splitpath FullPath2))                                    ;;;  I get                ("U:" "\\100000\\" "mech" "") break path in 4 pieces
(setq GetDrive (nth 0 split_path))                                                 ;;;  I get                 "U:"
(setq GetPNumber (nth 1 split_path))                                          ;; ;  I get                "\\100000\\"
(setq DirList (dos_dirtree (strcat GetDrive GetPNumber)))
DirList return a list of subfolders inside the folder "\\100000\\"...
("U:\\100000\\" "U:\\100000\\elec\\" "U:\\100000\\mech\\" "U:\\100000\\pl\\"
"U:\\100000\\Revit 2016\\" "U:\\100000\\Revit 2016\\!CAD-LINKS\\"
"U:\\100000\\Telecom\\" "U:\\100000\\x-refs\\")
I need to get the name of the "REVIT 2016" (is not always the same name) and make sure the \!CAD-LINKS\\" exist.
Any help is appreciate..
DC
paullimapa
Try this to check for Revit folder:
(foreach itm DirList (if (wcmatch itm "*Revit*")(setq RvtList (append (list itm) RvtList))))
!RvtList will return:
("U:\\100000\\Revit 2016\\!CAD-LINKS\\" "U:\\100000\\Revit 2016\\")
Then to check for !CAD-LINKS folder:
(foreach itm RvtList (if (wcmatch itm "*!CAD-LINKS*")(setq CADList (append (list itm) CADList))))
!CADList will return:
("U:\\100000\\Revit 2016\\!CAD-LINKS\\")
or nil if it does not exist
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
thank you so much Paul... you got it!!
paullimapa
