polyline fillet or stretch creates zero length line segment v2013
When I stretch or fillet this polyline it creates the 2 zero length lines (when exploded) which my laser picks up and skips over. Is there a way to stop or at least predict when this will happen? It is unrealistic to have to explode and check every polyline you fillet or stretch. Please help...
Patchy
You could ask the Customization Group see if an autolisp can be made to eliminate a zero length in a polyline.
If they are individual lines, remove a zero length line routine is all over the web.
Sofia.Xanthopoulou
Hi @Anonymous,
this might be a matter on how this line has been created. Please use the methods described in this article.
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
No the issue is just in polylines. What/where (link) is the Customization Group?
Patchy
Sofia.Xanthopoulou
I will move your post to the customization forum Smiley Happy
Regards
hmsilva
Use the 'Overkill' command with the 'Optimize segments within polylines' option checked, to remove the zero length segments.
Hope this helps,
Henrique
