Plugin bundle load fails
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
as the title suggests, I am playing around with plug-ins and bundles. After referring to the manuals, I created a .bundle folder containing a basic .xml file:
<?xml version="1.0" encoding="utf-8" ?> <ApplicationPackage SchemaVersion="1.0" AppVersion="1.0" ProductCode="[Add Unique Plug-in GUID Here]" Name="Test app" > <CompanyDetails Name="Company name" Email="support@company.com" /> <Components> <RuntimeRequirementsOS="Win32|Win64|MacOS"Platform="AutoCAD|AutoCAD*"/> <ComponentEntry AppName="Probni app 1" ModuleName="./Contents/test01.lsp" /> </Components> </ApplicationPackage>
Since I'm interested in local installation only, these are the basic contents the xml file should have. Also, the module "test01.lsp" referred to is trivial:
(defun test01 () (princ "Yello") (princ) )
Now, I tried copying this .bundle folder to:
C:\ProgramData\Autodesk\ApplicationPlugins
C:\Program Files\Autodesk\ApplicationPlugins
C:\Users\[Username]\AppData\Roaming\Autodesk\ApplicationPlugins
In all cases, when I launch AutoCAD, it displays a bubble in the upper right which says it was unable to load unnamed app. Also, the log it creates looks pretty useless, and there is a lag of about 10 seconds until AutoCAD starts responding again.
I was looking forward to this easy way to structure applications, but it doesn't look so easy after all. Any suggestions are highly appreciated.
