Add ( ) in attributes
Message 1 of 18
hi
someone can help me with this please?
i try to mofidy many existing attributes (but only the selected objects), i want to put every value into ( )
my bloc name is ANCHOR_ANNO and have  6 attributes
GUY1
GUY2
GUY3
GROSSEUR
ANCRE
ECRAT
some attributes are empty and i want to skip those attributes if posssible
thanks a lot
Accepted solutions (4)
Replies (17)
Message 2 of 18
gdefilo
Hi jonathan.t.d.1985,
simply use the "find" command with the replace option. Look for the blocks containing the attributes you want to change and substitute the old text string with the new.
Just simple as that!
Hope this helps,
Giancarlo
Message 3 of 18
i have 200x the ANCHOR_ANNO bloc in my dwg. and i want modify 125 of them only. some of unselected have the same value that many in selection that i want to modify that why i want a lisp or a macro line to modify attributes
develop your idea if you can help me with this option 🙂
i forgot to specify that selected blocs have a different layer that unselected
Message 4 of 18
gdefilo
Which is the difference between the blocks to change and the ones not to change?
Only their position?
Do you select them manually? Are they on different layers? What else?
Giancarlo
Message 5 of 18
Yes the position are always different. this is the most commun difference. but the layer and the color are are different too
the ( ) and purple color mean this is an old block replaced by the new (red) and the purple value are obsolete and the red are now effective
i can select them by select similar because they are on different layers. that only select the bloc with the layer removed
if you need more info let me know
Message 6 of 18
gdefilo
So, as far as I can understand, you could "isolate" the "purple" layer, or select similar, as you prefer. Then, use the "find" command to substitute the text strings in the selected blocks.
It will do all the job because you can use the "replace all" option.
Have a look at this:
http://cadsetterout.com/autocad-tutorials/find-and-replace-text/
hope you will find it useful,
Giancarlo
Message 7 of 18
devitg
Please upload a sample dwg
Message 8 of 18
hi
i post the sample asked Davitg.
it containt a small aera where i have to add new value block in red and identify obselete value in purple and ( ). the ( ) is not placed yet to let you try if you have any idea.
many thanks
Message 9 of 18
gdefilo
Hi jonathan,
in my opinion there's no need to apply a LISP routine or other.
Just go on through these steps:
- select similar blocks "anchor_anno" that are on "removed" layer;
- launch the "find" command;
- in the "find what" box type the text string you want to substitute;
- in the "replace with" box type the same text with ( );
- check "list results";
- check "block attribute value";
- press "find";
- should appear a list of values;
- press "replace all";
- go on with these steps for all the values you have to change.
I wouldn't do it other way.
Hope this helps,
Giancarlo
Message 10 of 18
hmsilva
@Anonymous wrote:
hi
many thanks
Hi Jonathan,
perhaps something will do the trick...
(vl-load-com)
(defun c:demo (/ atts i obj ss str)
    (if (setq ss (ssget ":L" '((0 . "INSERT") (66 . 1) (2 . "ANCHOR_ANNO") (62 . 6))))
        (repeat (setq i (sslength ss))
            (setq obj  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
                  atts (vlax-invoke obj "GetAttributes")
            (foreach att atts
                (if (and (/= (setq str (vla-get-textstring att)) "")
                         (not (vl-string-position (ascii "(") str))
                    (vla-put-textstring att (strcat "(" str ")"))
    (princ)
Hope this helps,
Henrique
Message 11 of 18
jdiala
@Anonymous wrote:
hi
If the blocks are already selected, why do you need a lisp routine. Just open the properties dialog box and edit the attributes there.
Message 12 of 18
Because i selected more that 100 blocs and attributes are different for many blocs, into properties dialog box the field attribut are *varies* and i fail to add ( ) without change value
Message 13 of 18
Henrique i have to thanks you again because your lisp work very well! (but i removed the fist line)
i never used lisp before and i didn't understand anything about the syntax but i will read tonight about and try to adapt the code to an other bloc. but This bloc have 2 attributes and the first will need only "(" and second attribute will have ")"
my challenge this w-e will be to find How list or identify attributes in a bloc
any tip, comment or document will be accept 🙂
Message 14 of 18
hmsilva
You're welcome, Jonathan!
The 'demo' will select 'ssget' inserts (0 . "INSERT") with the name (2 . "ANCHOR_ANNO") wite attributes (66 . 1) and color 6 (62 . 6), will exclude locked layers ":L"
Process all selected objects as vla objects, (setq obj  (vlax-ename->vla-object (ssname ss (setq i (1- i))))
get the attributes as list of atributes (vlax-invoke obj "GetAttributes")
test if the atribute textstring is not empty (/= (setq str (vla-get-textstring att)) "")
and test if in atribute textstring dont exist a "(" to not add more then one if a user select the same block twice (not (vl-string-position (ascii "(") str))
if the tests are true, put the parenthesis in the textstring (vla-put-textstring att (strcat "(" str ")"))
For the other block, is the name the same?
If not, select the block chamging the name, test for the tag,
if first tag (vla-put-textstring att (strcat "(" str ))
if second tag (vla-put-textstring att (strcat  str ")"))
To study the functions, open the code in vlide, highlights the function and press the button with a ? it will open the help files in the selected function...
EDIT: some sites, AfraLISP   Jeffery P Sanders  Lee Mac
Hope this helps,
Henrique
Message 15 of 18
Hi Hmsilva
i'm new into lisp language i tried to build  a similar code but i failed
i made this code
(defun c:demo (/ i s B)
(if (setq s (ssget "_:L" '((0 . "INSERT") (2 . "ANCHOR_ANNO") (66 . 6))))
    (repeat (setq i (sslength s))
      (setq b (ssname s (setq i (1- i))))
      (setpropertyvalue b "POLE_NO" (strcat "(" (getpropertyvalue b "POLE_NO") ")"))
      (setpropertyvalue b "HEIGHT" (strcat "(" (getpropertyvalue b "HEIGHT")))
      (setpropertyvalue b "YEAR_ADDED" (strcat (getpropertyvalue b "YEAR_ADDED") ")"))
  (princ)
but i would use your help to ugrade it and add into:
ALSO check in attribute YEAR_ADDED i put ")"  not "("
i don't want to skip empty attributes in this lisp then i don't need:
Many thanks again!
John
Message 16 of 18
hmsilva
Hi John,
your code have na error in ssget filter list...
The group code 66 it's an atribute flag.if 1, the insert have attributes.
(66 . 1)
The groupe code for índex color is 62 and (62 . 6) is for color 6.
If you change the filter list
to
(setq s (ssget "_:L" '((0 . "INSERT") (2 . "ANCHOR_ANNO") (66 . 1) (62 . 6))))
it should select INSERTs with the name ANCHOR_ANNO with attributes, color 6 and not in locked layers.
But if the user runs the code more than once in the same INSERT, the code will continue adding parentheses to the text string, regardless the parentheses existence already in the string...
I would suggest to add a test before add a parentheses, i.e.
(if (not (wcmatch (setq str (getpropertyvalue b "POLE_NO")) "(*"))
   (setpropertyvalue b "POLE_NO" (strcat "(" str ")"))
Probably something like this:
(defun c:demo (/ b i s str)
   (if (setq s (ssget "_:L" '((0 . "INSERT") (2 . "ANCHOR_ANNO") (66 . 1) (62 . 6))))
         (if (not (wcmatch (setq str (getpropertyvalue b "POLE_NO")) "(*)"))
         (if (not (wcmatch (setq str (getpropertyvalue b "HEIGHT")) "(*"))
            (setpropertyvalue b "HEIGHT" (strcat "(" str))
         (if (not (wcmatch (setq str (getpropertyvalue b "YEAR_ADDED")) "*)"))
            (setpropertyvalue b "YEAR_ADDED" (strcat str ")"))
   (princ)
Untested....
Hope this helps,
Henrique
Message 17 of 18
thanks so much for your help!
i applied your idea of test but i used and other option
[code]
(if (not (vl-string-search "(P" (getpropertyvalue b "POLE_NO")))
(progn
);progn
);if
[code]
Message 18 of 18
hmsilva
[code]
(progn
);progn
);if
[code]
If 'POLE_NO' text value will always start with P, then it's a good test...
Henrique
