Plot Parameters Problem
alexisgacia
alexisgacia
I'm having problem with the plot command. Sometimes the parameters are not the same. So it will give error during the process or it will stop in the middle of the batch process.
(COMMAND "_.PLOT"
"Y" ;; Detailed plot configuration? [Yes/No] <No>:
"" ;; Enter a layout name or [?] <LAYOUT>:
"PublishToWeb JPG.pc3" ;; Enter an output device name or [?] <DWG To PDF.pc3>:
"" ;; PublishToWeb JPG.pc3 Enter paper size or [?] <Sun Hi-Res (1600.00 x 1280.00 Pixels)>:
"Landscape" ;; Enter drawing orientation [Portrait/Landscape] <Landscape>:
"N" ;; Landscape Plot upside down? [Yes/No] <No>:
"EXTENTS" ;; Enter plot area [Display/Extents/Layout/View/Window] <Window>:
"FIT" ;; Enter plot scale (Plotted pixels=Drawing Units) or [Fit] <1=2>:
"0,0" ;; Enter plot offset (x,y) or [Center] <Center>:
"N" ;; Plot with plot styles? [Yes/No] <Yes>:
"." ;; Enter plot style table name or [?] (enter . for none) <PWA_COLOR_A1.ctb>:
"Y" ;; Plot with lineweights? [Yes/No] <Yes>:
"N" ;; Scale lineweights with plot scale? [Yes/No] <No>:
"N" ;; Plot paper space first? [Yes/No] <No>:
"N" ;; Hide paperspace objects? [Yes/No] <No>:
(strcat (getvar "dwgprefix") "Exp2013\\" (getvar "dwgname") "v1.jpg")
"N"
"Y"
It will give the following problem
_.PLOT Detailed plot configuration? [Yes/No] <No>: Y
Enter a layout name or [?] <Model>:
Enter an output device name or [?] <None>: PublishToWeb JPG.pc3
Enter drawing orientation [Portrait/Landscape] <Portrait>:
Landscape Plot upside down? [Yes/No] <No>: N
Enter plot area [Display/Extents/Limits/View/Window] <Display>: EXTENTS
Enter plot scale (Plotted pixels=Drawing Units) or [Fit] <Fit>: FIT
Enter plot offset (x,y) or [Center] <0.00,0.00>: C
Plot with plot styles? [Yes/No] <Yes>: N
Enter plot style table name or [?] (enter . for none) <>: .
Plot with lineweights? [Yes/No] <Yes>: Y
Enter shade pEnter a layout name or [?] <Model>:
FIT Enter plot offset (x,y) or [Center] <0.00,0.00>: C
Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visual styles/Rendered] <As displayed>: N
Enter file name <C:\Users\AlexPalaboy\Desktop\Test\Sai\SmallFiles\Exp2013\test1 - Copy-Model.jpg>: N
Save changes to page setup [Yes/No]? <N> N
Proceed with plot [Yes/No] <Y>: C:\Users\p009790c\Desktop\Test\SEnter file name <C:\Users\AlexPalaboy\Desktop\Test\Sai\SmallFiles\Exp2013\test1 - Copy-Model.jpg>: N
Save changes to page setup [Yes/No]? <N> N Proceed with plot [Yes/No] <Y>: C:\Users\AlexPalaboy\Desktop\Test\Sai\SmallFiles\Exp2013\Exp2013\test1 - Copy.dwgv1.jpg
Yes or No, please.
; error: Function cancelled
or
Is there any solution for this kind of problem?
Thanks in advance
Sea-Haven
Just a guess what happens if file exists already that can cause a overwrite yes no question that will not occur if file does not exist, use findfile etc to check 1st does it exist then will need 2 defuns one with a extra Y.
andelo523
when I go through the plot process, I have other prompts. I guess it depends most likely which space you plot (model or paper space). Maybe you can separate that in your Batch.
Also, @Sea-Haven is right, the existing file could cause an overwrite question. But it's also not that much of a problem if you got a new clean folder. 😄
I have these prompts in model space:
_.PLOT
Enter an output device name or [?] <PublishToWeb JPG.pc3>:
Enter plot area [Display/Extents/Limits/View/Window] <Extents>:
Plot with plot styles? [Yes/No] <No>:
Enter file name <>:
And this code works in model space:
(COMMAND "_.PLOT"
 "" ;; Enter shade plot setting [As displayed/legacy Wireframe/legacy Hidden/Visual styles/Rendered] <As displayed>:
 (strcat (getvar "dwgprefix") "Exp2013\\" (getvar "dwgname") "v1.jpg") ;; Enter file name
 "N" ;; Save changes to page setup [Yes/No]? <N>
 "Y" ;; Proceed with plot [Yes/No] <Y>:
alexisgacia
I set always to Layout before I plot but no avail.
What I did is I add delay before I start to plot.
(setvar 'CTab (car (layoutlist))) ; Focus to first layout
(repeat 3000 (setq a "z"))
(-Plot...)
(repeat 1000 (setq a "z"))
I don't know if this is right, but it works now. 33 files and counting, still no error. Still checking.
