Plot Object Lineweights - Default to OFF
jlaidle1
jlaidle1
Is there a variable that can control this option to be unchecked by default, or a LSP that can do that?
John Laidler
ITO - Application Management
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Moshe-A
@jlaidle1  hi,
As far as i understand the plot dialog is filled with a predefined page setup name. if you define a custom page setup  and disable the Plot object lineweights you'll get what you want?!
(setq acad (vlax-get-acad-object))
(setq doc (vla-get-activedocument acad))
(setq plcfgs (vla-get-plotconfigurations doc))
(setq pcfg (vla-add plcfgs "setup1" :vlax-true))  ; model page setup
(vla-put-PlotWithLineweights pcfg :vlax-true) ; plot using plotstyle
(vlax-release-object pcfg)
(vlax-release-object plcfgs)
(vlax-release-object doc)
(vlax-release-object acad)
untested
moshe
CodeDing
@jlaidle1 ,
Until somebody MUCH more experienced than I provides you with some sort of method to permanently turn off that value, I am going to HIGHLY recommend you do the following..
1). Find your default template location..
2). Navigate to that file location and create a copy of the existing template..
3). Open the original template, Modify ALL layout tab Page Setups and UNCHECK that box (Select OK when finished)..
4). Save this .dwt over the original file (You still have a copy)..
5). Open a new default drawing (since it is apparent you're not using custom templates).
6). Reap the benefits of your labor..
Best,
~DD
ronjonp
My buddy John! 🙂 Add this to your startup .. although named page setups as mentioned above are a better solution IMO.
(vlax-for l (vla-get-layouts (vla-get-activedocument (vlax-get-acad-object)))
  (vla-put-plotwithlineweights l :vlax-false)
