- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, now my work needs to get the value of multi dimensions in attached drawing and input in Excel file. I need your help to export them as the below information:
1. The value of dim is mm but the value after export is meter.
2. The exporting value must have 03 numbers after decimal point (e.g: If value of dim = 1,0514 mm => exporting value will be 1.051).
3. Please refer the attached lisp named "D2E" (export drawing text to Excel that hosneyalaa made for me - https://forums.autodesk.com/t5/user/viewprofilepage/user-id/6591997).
4. Please refer the attached lisps that extracts dim value to field in drawing with mm and meter units that named "mmD2F" and "mD2F".
Thank you soo much and best regards.
