Rename an xref that I do not know the name lisp Hello good evening
Message 1 of 11
I need your help, I have been asked at work to change the names of the references in multiple files and I wanted to do it with a bath script but I have seen that they have different names, so the only thing I know is the file " dwg "to which it is referenced which is always the same, let's see if you can give me a little hand to do it in lisp and then execute that lisp with a script in each plane.
Greetings and thank you very much for your help
Replies (10)
Message 2 of 11
pbejse
@Anonymous wrote:
.. so the only thing I know is the file " dwg "to which it is referenced which is always the same..
How is that again ? I'm not understanding that bit 🙂 We are talking about more than one xref in one file YES?
Message 3 of 11
hak_vz
@Anonymous  In other words, what you want to say is that you have multiple files that in xref have same files but those references were (or are not) renamed by users or are not named according some standard.
Usually reference name equals to file name. Since xrefs are special block object their name can be changed. For large set of drawings you can use batch file, but for smaller set of files this can be done by simply running a script inside each file.
Let suppose a scenario where you have CSV with desired xref name and referenced file name stored in CSV file.
CSV record would be:
wanted reference name 1, file path or name1
wanted reference name 2, file path or name2
wanted reference name 3, file path or name3
We would first create a list of all files referenced inside whole file set to create CSV file with unique set of file names (if references are inside same directory) or file paths if not. YOu would edit that CSV according to above format , and then simple lisp file can be executed on all files to make changes in accordance to it.
Miljenko Hatlak
Message 4 of 11
Thanks for helping me, the referenced file is called "Substation.dwg" but inside the file where that refx is inserted, some call it "Substation layout", "subestation", "Layout" and I want them all to be called the same, apart from that , I have another reference called "Format A3"
Greetings
Message 5 of 11
pbejse
Substation.dwg will be "Substation"
Format A3.dwg ->  "Format A3"
In other words keep the name of the drawing file as Reference name
OR
You want a specific Reference name per Xref?
Substation.dwg --> preffered name "Substation Layout"
These questions are being asked as so there are no confusion @Anonymous
Message 6 of 11
hak_vz
@pbejse   I have started working on code using Kean Walmsley's  batch-processing-autocad-drawings-from-lisp-without-sdi .  Attached code should be modified  (in comments) to enable generation of file list inside multiple directories and creation of list to change names of xref blocks. At the moment I'm flooded with work so if you can use this
Miljenko Hatlak
Message 7 of 11
pbejse
or --> Repair XREF Names from Autodesk AppStore, best of all, its FREE
Message 8 of 11
Shneuph
I'd have to look into it later, but I'm wondering if you can do this with "reference manager" which I think comes standard with newer releases of AutoCAD?
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 9 of 11
hak_vz
Here is a lisp file that resets external reference names  to be  equal to its file name.
You can either run it at file load or inside batch
(defun c:resetXrefs nil (resetXrefs))
(defun resetXrefs ( / getXblocks str_to_lst xblocks xref fname)
	(defun getXblocks ( / adoc name lst)
	  (vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
	  (if (equal (vla-get-IsXref block) :vlax-true)(setq lst (cons (vla-get-Name block) lst))))
	  lst
	(defun str_to_lst (str del / len lst pos )
		(setq len (1+ (strlen del)))
		(while (setq pos (vl-string-search del str))
			(setq lst (cons (substr str 1 pos) lst)
				  str (substr str (+ pos len))
		(reverse (cons str lst))
	(if (setq xblocks (getXblocks))
		(progn
			(foreach xname xblocks
				(setq xref (vla-item(vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) xname))
				(setq fname (last (str_to_lst (vlax-get xref 'Path) "\\")))
				(command "RENAME" "B" xname (substr  fname 1 (vl-string-position (ascii ".") fname)))
			(princ "\nAll x-refs names were reset to its file name!")
	(princ "\nDone")
	(princ)
Miljenko Hatlak
Message 10 of 11
Thank you very much everyone for your answers, I will try to do what you have told me, to see if I can do it.
Pbejse, if I have an external reference that the name is always the same "Subestation.dwg. What happens is that inside the plane, each person has named it in a different way and I would like them to all have the same name" Subestation layout "
Greetings
Message 11 of 11
pbejse
What you are wanting is to supply the preferred name, Do you have system for naming the reference? or just random name, if the latter then you need to "source" of list of drawing files and its preferred name, it can be an external file or a dialog that prompts the user for Search and Replace.
That will throw the Autodesk app link i posted out of the window then 🙂
