- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello all,
I was trying to solve the following problem for months: I want to pick a point (or enter manually) anywhere inside the attached table and get the name of the cell I picked into. For example (see attached drawing), when i pick the point with coordinates 7435680,4980930 the message D33 (the name of the cell) should appear at command line or anywhere as local variable.
Note that the above mentioned table is not the real table but rather area divided into rows and columns 22500x15000 drawing units. It is important to keep above dimensions of the cells. Also, so called "table" won't be visible in drawing, I just want to load the lisp, enter (or pick) the point and get the name of the cell.
Hope I was clear enough. Any help would be highly appreciated, thank you very much.
Branko
